Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 110 11 12 13 1416 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Thu May 08, 2014 6:23 pm
Wooh! The first preset that uses these new features arrived today and it sounds *spectacular*. :D
PostPosted: Thu May 08, 2014 6:54 pm
Yes Hans its works good :D
Garbage in is Garbage out !
PostPosted: Thu May 08, 2014 7:49 pm
I see some strange behavour from 7.41 and this last beta in KNEE sliders . In 7.41 they "do nothing" when i set them to 32db , but in this last beta it causes lowering the level ? Is that strange only to me or is some bug/was some bug.
PostPosted: Thu May 08, 2014 8:52 pm
maybe they are now actually working. (did't check that)
PostPosted: Thu May 08, 2014 9:37 pm
I couldn't like this beta. My MB setting sounds completely different compared to 7.41. I use RMS detection and the preset was very consistent till 7.41.
Now there's weird pumping effect and importantly I see more compression happening in this beta. I don't know precisely what but something's wrong here.
visit website
PostPosted: Thu May 08, 2014 10:00 pm
Can you send me your preset (or tell me which it is) so I can check?
Hm... It could be that this change is the reason why the new presets sound so much better - if something is wrong with the old presets (that don't use flat tops) the new ones would also seem much better in comparison...
PostPosted: Thu May 08, 2014 10:54 pm
CONFIRMED. Existing presets sound HORRIBLE with these settings because something is broken
Edit: Your'e right. It's Knee. It either didn't work before, or it works incorrectly now. But something is definitely very wrong.
PostPosted: Fri May 09, 2014 12:07 am
I'm running a new build now where this is fixed.
PostPosted: Fri May 09, 2014 10:56 am
New beta: BETA742-016. Fixed the compressor Knee bug in 015.
Windows stand alone: http://www.stereotool.com/download/ster ... 42-016.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 42-016.exe
Windows VST 32: http://www.stereotool.com/download/vst_ ... 42-016.dll
Windows command line: http://www.stereotool.com/download/ster ... 42-016.exe
Changes:
- Fixed the compressor Knee bug in 015.
- Added the first few new presets, and removed a bunch of others
Old Changes:
- Lots of small issues that might cause problems on different systems/plugin hosts etc. resolved: Rounding error in compressors, Marian sound card driver issue (was solved in BETA011), ...
- Added 'Flat tops' in Multiband Compressor and Natural Dynamics, with different band contents and improved crossover/flat output behavior.
- Added experimental DeLossifier (MP3 artifacts removal filter). So far it only reduces pre-ringing a bit.
I think there's more - will look through the changes later to see if I missed anything.
List of reported bugs:
- AM support doesn't work properly: viewtopic.php?f=2&t=5512&p=24635#p24635 FIXED
- Linux version crashed - FIXED
- Crash in 64 bit VST plugin in compressor - SHOULD BE FIXED NOW
- Hangup with Marian Windows 7 driver: WORKAROUND AVAILABLE, still busy attempting to pinpoint the cause together with Marian.
- Dotted area in ASIO input buffer (GUI only) TO BE FIXED
- Maybe change band 2 band shape (feedback Bojcha) -> apparently not
- Optimize new MB flat (1 FFT instead of 9) - DONE
- Old Flatness slider must be disabled when 'Flat tops' is enabled; other checkbox right to 'Flat tops' might be removed again. - DONE
- Fix Perfect Declipper keyboard input so I can also release a new declipper version
- Check performance DONE, difference is less than 1%
- Add presets ALMOST DONE, waiting for Thorium6 update/web version
- Change version number to 7.42
- Release
PostPosted: Fri May 09, 2014 3:32 pm
Nice Beta ;) Testing.....
