Post new topic  Reply to topic  [ 146 posts ]  Go to page Previous 110 11 12 13 14 15 Next
PostPosted: Sun Oct 15, 2023 12:29 pm
Hi I have a problem with WatchCat version from the site of ThimeoWatchCat_64_installer_BETA1011-015
Immediatly after detecting new files to process it close without warning.
There is somewhere logs to know why ?
Regards
Stef
PostPosted: Sun Oct 15, 2023 7:08 pm
Ok so we're going this way? Saved presets only load processing... Hans, explain to me why?
PostPosted: Sun Oct 15, 2023 8:04 pm
Hi, what do you mean?
PostPosted: Sun Oct 15, 2023 8:21 pm
When I load a preset from my PC, it does not load as I saved it, look at the check marks, only processing is loaded
PostPosted: Sun Oct 15, 2023 9:49 pm
Are you in the Processing tab of the presets? If so, it will only select Processing by default - but you can check the others to load those as well.
PostPosted: Sun Oct 15, 2023 10:46 pm
I load a saved preset from "Import preset from file" and the preset is saved with repair and hd settings but when I load it only processing is checked
PostPosted: Mon Oct 16, 2023 1:22 am
Oh. I see what's wrong now. If you click on "Import preset from file", the selection appears to be what the selection was the last time you loaded a preset from the list.
PostPosted: Mon Oct 16, 2023 10:20 am
Fixed, BETA016 is posted.
PostPosted: Mon Oct 16, 2023 1:05 pm
Hi Hanz,
Do you see my problem with WatchCat ?
Here other example wehre WatchCat crash after some treatment
and here is with the error:
Do I need to send email to support ?
Thanks
Stef
PostPosted: Mon Oct 16, 2023 2:02 pm
Hi Hanz,
I couldn't reproduce it yesterday but I just managed to get it to crash on my end. I think I know what's wrong, but I can't get it to reproduce anymore, so it's hard to verify that my fix works.
Edit: It pretty much reproduces now.
Edit: I think it's fixed. Something went wrong if multiple processing chains started simultaneously on startup.
