Post new topic  Reply to topic  [ 151 posts ]  Go to page Previous 110 11 12 13 1416 Next
PostPosted: Sun Apr 03, 2011 10:18 pm
BETA620-027:
I performed another full build. Also made one very minor change: In some cases, extremely loud highs could be reduced too much. That should be fixed now.
WOOPS. THE CORRECTION I MADE CONTAINS A BUG. DO NOT USE THIS VERSION!
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-027.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-027.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-027.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-027.dll
Command line version: http://www.stereotool.com/download/ster ... 20-027.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-027 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-027 NOT AVAILABLE
PostPosted: Sun Apr 03, 2011 11:05 pm
Question to Bojcha and others: Do you hear any difference if you increase the 'subtract' slider a bit (say to 0.05 or 0.10)? Because I can't really say that I hear anything - but it does reduce the clipping quite a bit and hence should give cleaner highs.
Also, in the recent versions some extra filtering has been added due to which even a multiplier of 0% sounds _way_ better than before this new filter was added (on top of everything else, in every processing step the highs are clipped between -32767/+32767).
I'd like to reduce the effect of this new filter as much as possible, because in the end it causes (some, mild) distortion in the high frequencies.
So I would prefer:
- High value for Vib - 1.0 is high enough there!
- High value for Subtract
- Low value for Multiply
- Low value for Maximum
Fixed versions:
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 0-027A.exe
Stand alone version: http://www.stereotool.com/download/ster ... 0-027A.exe
Edit: Just setting 'subtract' to 0.05 already has a big impact on the amount of clipping that occurs.
Edit #2: Subtract to 0.08 and Multiply to 400% gives roughly the same result as the current settings, but with less clipping if the highs don't have that much volume effect.
Edit #3: Same with Subtract at 0.12, Multiply at 500% (new version will allow for this).
Edit #4: But the volume level of the lows IS affected by this. So keeping the default setting is probably better in the end. :cry:
PostPosted: Sun Apr 03, 2011 11:27 pm
Here's another track for testing S sounds and distortion: Christina Milian - When You Look At Me
PostPosted: Sun Apr 03, 2011 11:54 pm
After doing a lot of tests I'm going for:
- Subtract: 0.05
- Multiply: 360
For loud highs this behaves the same as Bojcha's settings, for softer highs or less effect on the lows the clipping is slightly reduced.
PostPosted: Mon Apr 04, 2011 12:00 am
Found another track which is causing problems with highs.
The beginning of Britney Spears - Till The World Ends (Single Version)
http://processing.jongerenwebsite.net/a ... s_test.wav
Edit: But new highs protection doesn't seem to fix it. Even with extreme settings.
The only way i can get rid of the S sound distortion is lowering the De-esser quite a bit. But then i loose too much highs.
Edit: Tried this track with breakaway and i have same problem.
PostPosted: Mon Apr 04, 2011 12:32 am
This filter is so much better then old De-Esser...
Old De-Esser works like ... De-Esser. :D This new filter is not lowering Highs almost at all, at level domain.
New default settings are good (beta27A) Not sure with this "substract" I have feeling that it's bit better at 0.01 - 0.0.5, but at 0.00 is good and more safe 'i think'.
I just tryed to tweak more mid-highs and highs in B-Town preset (comparing to O.11), seem new filter handles more highs comming from MB.
PostPosted: Mon Apr 04, 2011 12:34 am
Bojcha,
In your preset, why did you set 'Limiting strictness' to 0.0%? That does help the audio quality, but causes spikes in the end result which need to be lowered using a slower responding filter - hence causing volume effects.
PostPosted: Mon Apr 04, 2011 12:49 am
oops.. not overviewed.. will be fixed, i just checking "version4"
PostPosted: Mon Apr 04, 2011 12:50 am
Ok... Because with that setting, Hard Limit has to take over... :twisted:
Setting it too high won't sound good either, but SMALL values have very little effect on the audio quality. Say 5-10%.
PostPosted: Mon Apr 04, 2011 12:53 am
Ah, ok. I'll take a break then. I was just preparing the processed files for uploading...
