Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 155 posts ]  Go to page Previous 110 11 12 13 1416 Next
PostPosted: Wed Sep 12, 2018 12:13 pm
Hello Hans,
I had already reported the display bug concerning the multiband section 1 and 2 and which is also present in BIMP (Multiband)
the lines in question are problematic:
Link N-1->N.0=Link N-1->N
Link N-1->N.1=N-1->N
Link N-2->N-1.0=Link N-2->N-1
Link N-2->N-1.1=N-2->N-1
No translation possible
PostPosted: Thu Sep 13, 2018 12:51 am
hopefully this message is not posted twice but my problem is that since beta version 16 I have a non-working interface. An empty frame. I use the standalone 64 bit version on windows7. Does anyone also have this problem?
This issue is solved now. New build is running.
PostPosted: Thu Sep 13, 2018 8:29 am
Stereo Tool 9.03 BETA022
Windows stand alone: https://www.stereotool.com/download/ste ... 03-022.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-022.exe
VST: http://www.stereotool.com/download/vst_ ... 03-022.dll
VST: https://www.stereotool.com/download/vst ... 03-022.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-022.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-022.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-022.exe
Windows libsndfile-1.dll (needed for MicroMPX decoder and command line version, place in same directory): MicroMPX command line enc/dec: https://www.stereotool.com/download/libsndfile-1.dll
  • Fix GUI crash in 915x577 screen size on non-4K screens.
  • Put something on I/O page (it's empty now)
  • Put Dutch Moose and PFD presets in SST
  • Add Kantar support
  • Added PFD preset (literally dozens of people requested that). Still need to change the name, it's the 2nd Dutch Moose in the list (the name is too long, so I'll rename it to just PFD 2018)
  • Add MicroMPX decoder abonneer-IP
  • Fri: SST/uMPX interface
  • The BIMP on LQLL
  • Bug fix: Dehummer had a crackle since version 014. That's back to normal again now.
  • Test MicroMPX with Stokkemask - 0.5 dB -> Changing setting in Stereo Tool helps
  • Show a warning if Quality it not set to 150% for Latency 128 and 256.
  • Bass Clipper sounds horrible at 128, True Bass at 128 and 256 -> disabled.
  • Update Dutch Moose
  • Clipper: Bass section lowpass freqs should not be too close at latency 512, 256, 128. (Noticeable in Dutch Moose preset)
  • Check that The BIMP works, maybe add parametric eq
  • MicroMPX rate limiter
  • 192 kHz input is broken! Output is mono, something is going wrong
  • SST ID's
  • Crackle in 2nd PDF track -> Improved
  • Allow lower latency (6 ms, 9 ms)
  • Improve clipper sound 1-6 kHz area
  • License The BIMP
  • Updated Paul Thompson's and Bojcha's presets
  • Updated Dutch Moose preset (more highs. less deep bass, less stereo widening, sounds much cleaner)
  • Stok: Lower samplerates look less good (and that makes no sense test without LOWER) -> 44.1 is ok now (-0.01 dB), 40 kHz is clearly lower (-0.20 dB), still way better than before (it was more than -0.40 dB in 9.02).
  • Add MicroMPX plugin licensing [22]
  • Fix Pi build (Stokkemask NEON code)
  • Update LogInOut code
  • New Stokkemask mode now works well in all Strictness settings above 7 (below 7 it's not very strict)
  • Stok: Post filter caused NANs
  • Stok: Move start point to later stage? (TUESDAY)
  • Cleanup code for VST3 David
  • Turn BIMP *OFF*
  • DrawWave draws outside of screen in FM analyzer (TUESDAY) - apparently ok
  • Include MicroMPX - for real now [22]
  • Hide Matrix Stereo for now
  • Stok: Add post filter
  • Stok: Legacy CPU load back to that of 9.02
  • API: Audio signal VU meter, info about whether stream is good NOW.
  • Started with matrix-based stereo widener; not happy yet.
  • Stokkemask NAN and other exceptions solved. (from previous beta)
  • Stokkemask threading issue solved. (from previous beta)
  • Stok: Remove overlap shortcut for stricter result (increases CPU).
  • Stok: Measure mask in every stage for stricter result (increases CPU).
  • Stok: Apply measured results in every stage for stricter result (increases CPU).
  • Stok: Replace L-R reduction in final stages by total volume reduction.
  • Stok: Figure out how to adjust shape at different sample rates -> Found correct Gaussian window sigma value instead, applied for both processing and display (which were set differently before!)
  • Stok: Replace "Looseness (sounds better)" by something that moves the mask up and down.
  • Stok: 1e stage only inner
  • Stok: More steps at end, needs to be both tighter and have less effect (is that last thing still needed???)
  • Stok: Try reducing the audio level in the final stage - lowering highs has proven useless at that point. --> SEEMS TO WORK, but only do this as the last stage!
  • MicroMPX SWEEP
  • Fixed a crash in the "Limit instead" code (Advanced Clipper).
  • Removed (moved to Extreme Tweaker for possible future testing) some Stokkemask settings that had a bad effect on compliance. Good settings are 50% / 30% / 40 dB (without the 40 dB it should be fne too, but there's a bigger chance at overshoots at the bottom of the mask. 100% for the first value increases overshoots!!!!! 39 and 38 should be safe as well - but I haven't had time to measure those separately anymore. Anyway in the older versions this value was set to 0....... Setting it higher may cause an audio quality reduction.
  • Crash fixed
  • Stokkemask: Try I/Q Clipper mode, highs are coming out slightly too loud, due to LPF? Might be good enough... -> Idea doesn't work
  • Stokkemask: We don't care about CPU load, try adding more stages -> No effect
  • Stokkemask: Default back to 50% for safety - that way we don't have to worry about breaking older versions. And we still get 90% of the improvement that way.
  • More experimental stokkemask settings added.
  • Stokkemask: Improved further (looks about equally strict, but I can squeeze over 1 dB more anti-phase content through than with 9.02). NOTE: SETTINGS ARE DEFAULTING TO 9.02 BEHAVIOR BECAUSE I DON'T KNOW YET IF THE SIGNAL IS EQUALLY STRICT, AND I DON'T WANT SOMEONE TO GET FINED FOR HAVING STOKKEMASK OVERSHOOTS. To get the new behavior, set "New looseness 1" higher (50% should definitely be safe, I'm not sure about 100%), "New looseness 2" to 30%, and "Side level" to 40.
  • Improved Stokkemask - output is stricter (closer to the mask), so it has less impact on stereo separation. (*)
  • Memory usage reduced by about 12 MB
    PLANNED:
  • Release
  • Linux multiple instances
  • RDS urgent issue
  • Cntrct IN
  • Test preset that causes buffer to run empty - why? --> Settings issue, maybe add a popup for this situation (buffer is slowly filling up or running empty)...
  • RDS: Support for AF method B
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
  • uMPX decoder: Add multicast subscribe
New vs old Stokkemask measurement numbers, relative to 48 kHz no stokkemask, for audio with quite extreme stereo. Numbers are L-R loudness, L loudness
Freq     old/new          L-R    L
48   kHz no  Stokkemask:  0.00,  0.00 (reference)
48   kHz new Stokkemask: -0.62, -0.27 (0.46, 0.10 better than old!)
44.1 kHz new Stokkemask: -0.63, -0.22 (0.54, 0.11 better than old!)
40   kHz new Stokkemask: -0.82, -0.29 (0.65, 0.14 better than old!)
48   kHz old Stokkemask: -1.08, -0.37
44.1 kHz old Stokkemask: -1.17, -0.33
40   kHz old Stokkemask: -1.47, -0.43
PostPosted: Thu Sep 13, 2018 6:15 pm
Hans,
Is it normal that when we click on bypass button, for BIMP all effect (process) remain ?
Regards
Stef
PostPosted: Thu Sep 13, 2018 7:16 pm
022 DSP locks up within a minute of play. No matter which preset I use. GUI becomes unresponsive, but music continues.
PostPosted: Thu Sep 13, 2018 9:27 pm
Problem mentioned not detected here....
022 DSP on i7 5500 8Gb
PostPosted: Thu Sep 13, 2018 10:41 pm
I found it freezing when I switched from the main Processing screen to the IO section. Processing kept working, but the interface froze up. I killed it and restarted it.
PostPosted: Fri Sep 14, 2018 12:36 am
Due to the IBC I won't really have time to look into this (which is kinda bad, because I wanted to release this version before the IBC starts). Anyway, I have a setting myself on one pc that causes the program to start with an unresponsive GUI so it should be easy to figure out what's wrong.
PostPosted: Fri Sep 14, 2018 10:24 am
Yep! Same here...
PostPosted: Fri Sep 14, 2018 11:30 am
Hello to all,
Have you thought about starting again on a default configuration file, i. e. delete the stereo_tool.ini file (to start again on a good basis), maybe the error will no longer appear, because I am not the presence of this bug you describe.
