Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1104 105 106 107 108213 Next
PostPosted: Tue Jul 26, 2011 8:12 pm
no man a have too much specific songs ... no 100.1 %
But no sense ... I`ll make the same songs mix with -3 db .... there is no problem at all man ... just wait a little
PostPosted: Tue Jul 26, 2011 8:15 pm
And Why the loudness is diabled in Beta 80 ?
Thanks
PostPosted: Tue Jul 26, 2011 8:33 pm
The idea here was to see the quality ... forget about overshoots :) not exist ... don`t forget the hard limit checkbox .. this is for sure there is NO overshoots man :) BRICK I always use it for FM processing !!!
Just so you know... the hard limiter happens BEFORE the "post amp" level setting in ST.
PostPosted: Tue Jul 26, 2011 8:41 pm
Thanks
It shouldn't be?!
PostPosted: Tue Jul 26, 2011 9:04 pm
Loudness is not disabled only some part of it is disabled, you can still set the loudness slider.
At least in the stand alone version.
PostPosted: Tue Jul 26, 2011 9:15 pm
yes it is strange some.part in stand alone version is disabled
it is normal? thanks hanz
PostPosted: Tue Jul 26, 2011 9:51 pm
Testing the 80 version.
Distortion is noticable in voices. Loudness VU meter doesn't seem to be working in the standalone (didn't try other versions)
PostPosted: Tue Jul 26, 2011 11:21 pm
http://www28.zippyshare.com/v/65035567/file.html
Ok .. Here is the -3 db test mix
hope it`s ok for tests now
PostPosted: Tue Jul 26, 2011 11:46 pm
some part of loudness is disabled > show the exhibit
The loudness is active or not ?
the sound is very differenty than beta 79, due of the new clipper ?
Thanks Hanz
PostPosted: Wed Jul 27, 2011 12:09 am
@DJ DOGGY, the mpx recording is ok now for tests. The maximum hold is at 100.1% now as i expected.
