Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1102 103 104 105 106213 Next
PostPosted: Mon Jul 25, 2011 7:07 am
Yeah it would - at least for now...
but but but but... it made all my mp3s sound so gooood!
PostPosted: Mon Jul 25, 2011 7:51 pm
ho ho ho ... I finally listen to the competition of audio processing OMNIA 9 by Leif....
Guess what ? Saturated sound (unreal High`s) ,nothing better than Stereo Tool .Let`s say this is right that ST goes to this competition.
And have more balance of the sound (low`s , mid`s , high`s) .
So there is nothing to change in ST .
I have settings that no one can beat them in these kind of competitions .. No one trust me ? Just request them . and make a million tests if You wish ( even this mix at the competition )..... :) You will find the power of StereoTool . But i want this tests to be before any fundamental changes in ST.
This is because i saw that Hans is talking with Leif ..... i don`t remember his second name sorry .... to make some changes .
No.... sound from Omnia has more high`s like i said sounds like unreal high`s . The better sound balance in the receiver is for ST !!!!! Remember this . Limiting is like a BRICK .
I can make a mix to listen too. Just anyone say and i`ll make it .
PostPosted: Mon Jul 25, 2011 7:58 pm
make it !
PostPosted: Tue Jul 26, 2011 8:45 am
Ok may friend ... today after work i`ll take care of it .
PostPosted: Tue Jul 26, 2011 10:23 am
75uS (or 50uS) pre-emphasis composite recording (with -3dB = 100% modulation) would also be appropriate, for a fair test. :)
PostPosted: Tue Jul 26, 2011 12:07 pm
Yes please composite recording with 50us pre-emphasis, so we can listen to it by MPX tool.
PostPosted: Tue Jul 26, 2011 2:52 pm
BETA080:
Working on a new clipper. There are still some things wrong with it (mainly that it sounds a bit more harsh and distorted than before), I think I know how to fix it and I will soon (maybe tonight). Camclone will like it though: It's 0.3 dB louder than before AND more tightly clipped so you can now set the 'FM Overdrive' slider to at least 110%, increasing the level by approx. 1 dB (so almost 1.3 dB in total). And the mid-highs (around 5-10 kHz) are louder.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-080.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-080.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-080.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-080.dll
Command line version: http://www.stereotool.com/download/ster ... 20-080.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-080 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-080 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Remove Natural Dynamics Partially done, does the crash come from here?
- Big window output is smaller than normal one
- In FM calibration 38 kHz is NOT working. EDIT: And more bugs: 23 kHz is not at 23 kHz 28 kHz is not at 28 kHz 33 kHz is not at 33 kHz 43 kHz is not at 43 kHz 48 kHz is not at 48 kHz 53 kHz is not at 53 kHz.
- Add composite clipper
- Highpass before Multiband etc?
- Release 1 hour
- AGC: Sudden loud kicks (32:40) - much faster drop!
PostPosted: Tue Jul 26, 2011 4:12 pm
DJ-DOGGY : upload your test file AND your processed mpx 50 or 75 ms file with -3 db to compate it with other presets of stereotool or other processors :) !
Hans : YES IT IS LOUDER !! , so, no, i can clean up my multiband settings :)
We want MPX clipping we want MPX clipping we want MPX clipping !!!!!!
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: Tue Jul 26, 2011 6:01 pm
Ooook .....
Here we go ...
no saturated sound , no compression .... only limiting.
http://www66.zippyshare.com/v/1503452/file.html
Pre-emphasis is 50 us. In my country there is no 75us
The most important thing is to get the right volume from computer ( not from ST slider ) you know ...the good old speaker icon somewhere next to the computer clock.
Don`t forget that the sound is processed with 50 us which is +15 db at 15Khz . So the whole sound must be set at least -15 db because the level with pre-emphasis not to go above 0 db for maximum quality and no distortion . hope You got it :)
P.S : only 2 or 3 songs are Flac. Others are just MP3 .
PostPosted: Tue Jul 26, 2011 6:26 pm
And this should be.. ? FM Audio processing, with more then 100kHz output?
Sorry i don't understand.
