Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 19 10 11 12 1343 Next
PostPosted: Sun Jul 24, 2016 1:31 pm
(because it was way too high and causing problems with Audition among others)
the problem occured in Audacity, not in Audition. I cannot test in Audition yet, because only 64bit Plugins are supported. :roll:
btw i tried it in Audacity again, but it always crashes, if i click on ok or on the preview button. i would be great, if you can make work it again. i seems to be always the same error, als metioned in my last error report (in a PM i sent you the minidump data)
PostPosted: Sun Jul 24, 2016 5:28 pm
- Memory usage reduced a lot (still higher than 8.00 but a LOT lower than previous beta's).
- This seems to completely solve the crashes in Audition now
- Memory leaks caused by certain compiler options don't occur anymore, I don't know why...
Windows stand alone: http://www.stereotool.com/download/ster ... 01-013.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-013.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-013.dll
Known issues:
- Audition doesn't close. (Same problem as in version 7.84 and before, was solved in 8.00 but something is breaking this again).
- Display needs to be updated for all threads
- Display updates must happen in correct order (weird noise jumps otherwise)
- Delossifier web display needed
- Generate UIDs and use link
- Password for login?
- Type IP in web site
- TODO: Add exception if ignoring too high VST parameter numbers (Audacity bug!).
PostPosted: Sun Jul 24, 2016 5:32 pm
On my end this latest version (BETA013) works fine in Audacity. Might have been that same memory issue that caused problems in Audition.
PostPosted: Sun Jul 24, 2016 5:47 pm
i downloaded and tried this version now. but it still crashes if i click ok or the preview button. in contrast to the last beta the exception is catched by audition and the whole application isn't crashing. audacity writes in the log the following exception:
 <context>
    <exception code="c0000005" name="ACCESS_VIOLATION" address="111a3a0c"/>
    <registers>
      <eax>00000000</eax>
      <ebx>00000010</ebx>
      <ecx>00000010</ecx>
      <edx>00000010</edx>
      <esi>00000076</esi>
      <edi>00000087</edi>
      <ebp>57be1040</ebp>
      <esp>0145e95c</esp>
      <eip>111a3a0c</eip>
      <cs>00000023</cs>
      <ds>0000002b</ds>
      <es>0000002b</es>
      <fs>00000053</fs>
      <gs>0000002b</gs>
      <ss>0000002b</ss>
      <flags>00210202</flags>
    </registers>
  </context>
  <stack>
    <frame level="0" function="VSTPluginMain" offset="001743cc"/>
    <frame level="1"/>
if i switch back to beta 01 then i have no problems. :roll: did you need more information about the crash?
PostPosted: Sun Jul 24, 2016 7:07 pm
Huh, now it's suddenly crashing here too. Will first try to fix my own crash (which appears to be in the VST parameter handling).
PostPosted: Mon Jul 25, 2016 9:54 am
Ok so... For some reason Audacity is sending 8200 parameters instead of 4100. Audition does NOT do this with the same DLL. Which is really very strange. There might be a bug in Audacity that cannot handle more than 4096 parameters or something like that - I've added a few in the last weeks. --> Confirmed, with a few fewer parameters it works fine... Bug in Audacity!
For now I've added a check; when a parameter comes in with a too high number I just ignore it. I will add some exception message for it later, because I definitely DO want to get notified of bugs like this, instead of hiding them completely.
PostPosted: Mon Jul 25, 2016 1:14 pm
Beta13 still crashing at start. I think info from exception is the same
PostPosted: Tue Jul 26, 2016 1:00 am
Can you try the following?
1. Create a directory C:\temp
2. Run Stereo Tool and wait for this crash to occur
3. Close Stereo Tool, and send me the files C:\temp\StereoTool_Exceptions_Log.txt and C:\temp\log
There seems to be a problem with the memory pool, if that's indeed the case this should be logged *before* the exception that you posted. Which is why I really need these file.
Thanks!
Edit: Never mind! If you use the old (Digital) style Multiband compressor with 9 bands, you get an error. Will fix it now. Update tomorrow morning.
PostPosted: Tue Jul 26, 2016 8:58 am
- Crash with 9-band Digital multiband fixed
- Audition closes now
- Web server much more reliable, it can handle multiple requests simultaneously.
Windows stand alone: http://www.stereotool.com/download/ster ... 01-014.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-014.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-014.dll
Known issues:
- Display needs to be updated for all processing threads
- Quality between 100 and 150%?
- Service
PostPosted: Tue Jul 26, 2016 10:03 am
Here are files , but i think there is the same info as in the exception window.
Will try the new beta to see.
Edit: beta14 is starting normally
Edit2 : How to consider the "Hear" option ( i think the old Difference ) ?
When i press it in MB , i see that Clipper visual meter is disabled , but no other changes . When i press it at the AGC , MB and Clipper meters are disabled but again no other changes !? what to "Hear" ?
temp.rar [2.21 KiB]
Downloaded 210 times
