Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 19 10 11 12 1359 Next
PostPosted: Sun Jan 24, 2016 10:38 am
@radiofreak:
160 Bands sounds a tiny little less distorted, but there is IMHO not much of a difference. (...) 160 Bands sounds clearly better, much less mp3-like artifacts.
Huh? So what is it, not much difference or clearly better? And for MP3-like artifacts, I expect them in 160-band mode, not in 1-band mode. Or do you mean it's a lot better than the old 40-band mode?
Oh, I should have made that clearer: on modern content, which have already a lot of highs, I don't hear much of a difference. On older music, which doesn't have much highs, 160 Bands sounds smoother and less "ringing-like".
PostPosted: Sun Jan 24, 2016 12:22 pm
After several extensive tests with the beta 15 me a few little things are only noticed:
If there are extensive high hats, which rise in the spectrum of the loudness ago, then the transition between the original and the reproduction is very hard. This can sometimes be easy 3 db. Have you a solution for this? Can you on the basis of existing data reveal how the energies are distributed in the spectrum?
All in all, sounds the Beta 15 fantastic!
PostPosted: Mon Jan 25, 2016 6:15 pm
The risk when fixing this is that it starts to sound unnaturally (but I can try).
I have worked on optimizing the code today, new version is building now. CPU load is reduced a lot (I will know how much when the DSP build is finished). Also using less bands now.
Edit: Wooh! Factor 10 down! :)
Edit: Hm, it crashes sometimes when I change the settings. Except for that it seems ok.
PostPosted: Mon Jan 25, 2016 6:42 pm
7.85 BETA017
Windows stand alone: http://www.stereotool.com/download/ster ... 85-017.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-017.exe
Windows VST 32 bit: ----://www.stereotool.com/download/vst_stereo_ ... 85-017.dll
CHANGED:
- Improved Exciter performance Note: Crashes when you change settings, I will fix that.
- Exciter: Smooth curve to avoid ringing (which is now filtered out by later steps, but that's bad).
- Exciter: Add slider for Band Width
- Exciter: Add slider for Band Overlap
- Exciter: Add slider and checkbox (?) for Band Shape (half cosine, cosine, squared/square root)
- Added option to switch between 1 and 160 bands for Exciter.
- Exciter generates more highs than the previous version (which generated too little). The amount of filtering is reduced though!
- Improved Exciter: Increased number of bands from 40 to 160. MP3-like artifacts AND distortion should be gone now.
- Exciter: Calculate target amplification levels for each bin using white (?) noise!
- Fixed some Exciter issues (which might have been the cause of errors that some people reported).
- Improved Exciter: Now using 40 bands instead of 1
- Added some filtering to make sound less 'sandy' (distorted).
- Exciter: Check why it sometimes boosts audio around 10 kHz (?) more than it should (Johnnie Cash) - protection filter appears not to work completely. Compare what happens without protection filter! -> Fixed (more or less)
- Added a soft of exciter (not an FM exciter but something that generates highs). I've placed it (for now) under True Bass, and it cannot be configured yet. Not really sure what to make of it yet, I think I like it but it does sound a bit "rough" sometimes. Note: It can cause pre- and post ringing at higher latency settings (I will fix that later, first want to get a bit of a feeling for what it does).
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Try "True Bass" for highs -> Probably make a version where different modes (with/without filtering, with better HPF) are tested. Maybe also with multiple bands?? To reduce generated distortion.
- Exciter: Check why lowest part (just above start) is too soft.
- Exciter: Fix pre-ringing problem in initial filter (?)
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- O skin
- Show help in gui
- Blog post pre-processing
- Blog post MP3 and declipping
PostPosted: Tue Jan 26, 2016 4:34 am
It seems the "Voice Protection" setting of the classic multiband produces distortions (especially with piano instruments). The same settings sounds clear with Stereotool 7.03.
Here is a download of an example piano track:
http://ocremix.org/remix/OCR02928
The attached config produces distortions with 7.84, not with 7.03 - especially the loud part of the track beginning @ minute 3:16. The distortions dissappear when Voice Protection is set to zero.
test-distort.sts [74.81 KiB]
Downloaded 276 times
PostPosted: Tue Jan 26, 2016 4:26 pm
7.85 BETA019
Windows stand alone: http://www.stereotool.com/download/ster ... 85-019.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-019.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 5-019A.dll
CHANGED:
- Exciter: Fix 'bump' in spectrum at start frequency.
- Exciter: Make it possible to bypass 4x oversampling
- Exciter: Make multi-threaded
Note: The Exciter can take a few seconds to start working when you enable it the first time. (Enable "Blocking" to skip the wait, but then the whole chain will halt for about 0.2-1 second).
- MP3?
- O skin
- Show help in gui
PostPosted: Tue Jan 26, 2016 6:58 pm
Unfortunately, there is for the latest betas no VST version. :roll:
PostPosted: Tue Jan 26, 2016 7:15 pm
Works fine for me: Click me hard.
PostPosted: Tue Jan 26, 2016 7:56 pm
Thanks a lot for your help! Unfortunately, you could not click the original link. Then I now test the new version. :)
Edit: I have now tried the new version. What struck me the following:
With the default settings I get absolutely no result. I get so 1 : 1 the original. Then I change the "band Size" on 1, then I get a result. I now Increase the "Band Distance", then I get at low values, for example, around 30 very strange effects. It sounds a bit hollow. As soon as I push, however, the band size is slightly higher than 1, then comes no longer a result. Incidentally, the result does not sound as clear as in the earlier versions. It all sounds very washed out. In spectrogram you see something like a slight echo. Looks like when you use a very fast flanger effect. All this refers to the use of 160 bands. The switch "block at Startup" seems to show with me no effect. But what's interesting in the rest: The percussion instruments are better completed. These include in particular the tambourine. That had never works.
What still stands out: Somehow now act the new data shifted. The newly generated signals are now coming earlier than the original in the deep areas. That looks kind of very funny. That struck me with the following settings: 160 bands, band size 1, band Distance 100%, block on startup true
PostPosted: Tue Jan 26, 2016 11:58 pm
There's a reason why there was no VST link!!! The build wasn't finished yet, so you've just tested some old version (not sure which one).
I'll run a build now so you can test it properly
