Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 19 10 11 12 1335 Next
PostPosted: Sun Jul 12, 2015 3:13 pm
Ummmmm :D LOL
http://www17.zippyshare.com/v/grYoKvsT/file.html
And it doesn't matter - FM, non FM. So, for this reason I can't really test that version.
The exact same problem here
My radio station
http://amradio.ddns.net
PostPosted: Sun Jul 12, 2015 5:59 pm
Higher than 48000 Hz sample rates currently don't work. Cause is found and fixed here...
PostPosted: Mon Jul 13, 2015 1:53 am
Warning: Potentially buggy version
I will try to fix all the reported bugs starting a week from now, until then I'm focussing on some other things (audio and performance).
Stereo Tool 7.71 BETA009
Windows stand alone: http://www.stereotool.com/download/ster ... 71-009.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-009.exe
Still valid:
This version has a new slider, 'Ignore high frequencies above' (under CPU & Latency). You can enable this and select a frequency (19 kHz should be good for FM, since anything above 16.4 kHz needs to be removed anyway). This allows the processor to take some shortcuts... Which reduce the CPU load (more so at 48/192 kHz than at 44.1/176.4 kHz). This setting affects ALL the filters in Stereo Tool, not just the final clipper.
Warning: Known bug: Changing the value can cause a shift in input/output samples with yet unknown results; after restarting it should always be ok. So, it's advised to always restart Stereo Tool after changing or enabling/disabling this feature.
Old:
There are some big changes in the Composite Clipper in this version. The sound should be the same as before (within 0.02 dB or so). CPU load is much lower though. Please be careful with using this version for anything else than testing until proper functioning has been confirmed.
Note: If you want to use the new composite clipper CPU load optimization with Stokkemask, for now you should set the Stokkemask Quality slider to 3 (I still need to fix that).
- Some small optimizations
TODO 7.71:
- Fix optimizations
- Fix code #warnings
- Fix downsampling and Quality slider problems.
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF.
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% -> Started working on this
- Synchronization is broken in 008 (was ok in 007)
- VST multiple instances fails
- Make VST window bigger
- Clipper highs improvement
- Noise learning Micha
- EQ with 'standard' sliders.
TO DO WITH LEIF:
PostPosted: Mon Jul 13, 2015 7:39 am
I`m not using last 2 betas , but to ask if MPX white curtain working, because in my last installed - it`s freezed? This is next to the LEVELS .
PostPosted: Mon Jul 13, 2015 12:29 pm
Not completely fixed with the latest beta, I am getting a repetitive low frequency clicking sound that is only noticeable at times when input levels are low. Only at sampling rates above 48000 Hz.
J0HN II
PostPosted: Tue Jul 14, 2015 5:21 am
Turning "ignore high freqs" on definitely lowers CPU load, but causes the stuttering in my system. Otherwise, it's working OK.
PostPosted: Tue Jul 14, 2015 10:11 am
For me it`s imposible to continue to use ST when enable the "Ignore high freqs" option.
It`s the beta009.
ST freezes and shows this :
Edit : After close and reopen ST is running .
PostPosted: Tue Jul 14, 2015 9:26 pm
now sound quality more good.
why you delete my link booooooooooooo
PostPosted: Tue Jul 14, 2015 11:45 pm
It`s the beta009.
Ok this is helpful! Looks like there's a memory alignment issue, it appears that on newer hardware (i7's) this doesn't show up as an error anymore so I don't notice it....... Will look into it!
PostPosted: Wed Jul 15, 2015 8:20 am
It`s the beta009.
As i always said: AMD sees it all :)
