Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 19 10 11 12 1316 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Sat May 03, 2014 7:50 pm
real quiet around here.when does 7.42 arrive?
PostPosted: Sat May 03, 2014 9:39 pm
I'm working on several things simultaneously. None of them is good enough to post anything here yet though. I expect to post a new version in a few days.
PostPosted: Wed May 07, 2014 1:26 am
Mad scientist at work!! Never know what is in the weapon arsenal...
PostPosted: Wed May 07, 2014 4:44 pm
If hard limit is enabled, the output bar should never turn red ritght?
I'm not sure if it's just a GUI thing and the code correct but sometimes theoutput bar turns red...so overshoots.
''For FM output it should also always be enabled, to protect against overshoots.''
The Power of Sound
PostPosted: Wed May 07, 2014 4:50 pm
I know. That can happen occasionally, it's a very small overshoot which should have no effect on anything...
PostPosted: Wed May 07, 2014 5:00 pm
Ok Clear, I never noticed it before :geek:
The Power of Sound
PostPosted: Thu May 08, 2014 10:05 am
New beta: BETA742-015. Stability should be 100% ok again now!
Windows stand alone: http://www.stereotool.com/download/ster ... 42-015.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 42-015.exe
Windows VST 32: http://www.stereotool.com/download/vst_ ... 42-015.dll
Windows command line: http://www.stereotool.com/download/ster ... 42-015.exe
Changes:
- Lots of small issues that might cause problems on different systems/plugin hosts etc. resolved: Rounding error in compressors, Marian sound card driver issue (was solved in BETA011), ...
- Added 'Flat tops' in Multiband Compressor and Natural Dynamics, with different band contents and improved crossover/flat output behavior.
- Added experimental DeLossifier (MP3 artifacts removal filter). So far it only reduces pre-ringing a bit.
I think there's more - will look through the changes later to see if I missed anything.
List of reported bugs:
- AM support doesn't work properly: viewtopic.php?f=2&t=5512&p=24635#p24635 FIXED
- Linux version crashed - FIXED
- Crash in 64 bit VST plugin in compressor - SHOULD BE FIXED NOW
- Hangup with Marian Windows 7 driver: WORKAROUND AVAILABLE, still busy attempting to pinpoint the cause together with Marian.
- Dotted area in ASIO input buffer (GUI only) TO BE FIXED
- Add presets
- Maybe change band 2 band shape (feedback Bojcha)
- Optimize new MB flat (1 FFT instead of 9)
- Old Flatness slider must be disabled when 'Flat tops' is enabled; other checkbox right t.o 'Flat tops' might be removed again.
- Fix Perfect Declipper keyboard input so I can also release a new declipper version
- Change version number to 7.42
- Release
PostPosted: Thu May 08, 2014 2:08 pm
At this latest beta Memory jumps from 129k to 182k !
PostPosted: Thu May 08, 2014 3:45 pm
I don't see that here - which version are you using?
PostPosted: Thu May 08, 2014 4:38 pm
OHHHH sorryyyy i checked it back again.. its ok.
Sorry something i might done wrong...
