Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 492 posts ]  Go to page Previous 19 10 11 12 1350 Next
PostPosted: Thu Jun 09, 2022 7:24 pm
Thanks! It was fixed. :)
One suggestion for the new versions, the density controls were shortened by half (+/-6 instead of +/-12), and attack/release speeds were shortened by 3/4. Could they possibly be set back longer for more control?
By the way (off topic) I'm originally from Texas and grew up there. I noticed your location, Klorox.
PostPosted: Thu Jun 09, 2022 8:03 pm
That specific issue was about the old one.
I'm not touching the old web gui code with a 10 foot pole if I can help it :mrgreen:
PostPosted: Thu Jun 09, 2022 11:32 pm
We are currently running a release build for version 9.91 (old GUI, to fix some issues in 9.90), and because something failed this build has been running for almost 4 days now - I expect it to finish sometime tomorrow morning... This is taking up some of the build hardware, so I have a new new GUI beta, but only for Windows. You can find version 9.92-BETA001 in the top post.
PostPosted: Thu Jun 09, 2022 11:48 pm
I use the FM Output as a secondary output, but I don't have a Transmitter enabled, so the FM bar is darkened and disabled. Should the FM meter bar even be shown if the FM Transmitter is disabled?
PostPosted: Fri Jun 10, 2022 12:18 am
Still does not remember zoom, after old gui.
PostPosted: Fri Jun 10, 2022 1:24 am
Input, ND, IB, TB, SBB meter bars seem inverted. Also Natural Dynamics no longer has orange in the meter bar. 9.92 beta 1
I'm glad to hear you were able to successfully leave, lol!
PostPosted: Fri Jun 10, 2022 2:02 am
Another DPI scaling issue it seems. I can minimize to tray and it's 50% of the original size when restoring to my (4k at 200% DPI scaling) primary monitor. However, it restores to the correct size on my secondary monitor (1080p at 100% DPI scaling)
Win10 x64 9.92-001
PostPosted: Fri Jun 10, 2022 2:26 am
Win10 x64 9.92-001
It happens here too. Every time i minimize and restore it's smaller and smaller. :D
PostPosted: Fri Jun 10, 2022 4:18 am
Also, the meter for the Advanced Clipper’s bass clipper (to the right of the clipper) is inverted.
PostPosted: Fri Jun 10, 2022 8:38 am
Should the AGC wideband be added to the vertical AGC meter bar?
Do you mean the post AGC compressor? It already should have been in there. In fact, all the AGC meters were already in there.
They are automatically hidden when they're turned off.
