Post new topic  Reply to topic  [ 162 posts ]  Go to page Previous 19 10 11 12 1317 Next
PostPosted: Mon Aug 09, 2021 5:13 pm
Oops, fixed. Also fixed the Latency AGC "Remove higher peaks" issue; the settings for band 1/2 and band 3 were swapped.
can you elaborate a bit more since i use the Legacy AGC exclusively ?
See this image. The "Remove remaining peaks above" settings for band 1/2 and band 3 were swapped, so if you load an existing preset in the last beta's, the values (130% and 454%) would be 454% and 130%.
thanks. that change does not adversely affect my customized preset.
PostPosted: Fri Aug 13, 2021 4:03 pm
B36 & B37 - i see the MPX spectrum display drawing has been changed to a more "simplified" drawing.
i actually prefer the original detailed MPX spectrum display over this new simplified less detailed display.
PostPosted: Fri Aug 13, 2021 4:21 pm
EDIT nevermind, beta 37 the absolute highs spectrum is fixed.
PostPosted: Fri Aug 13, 2021 7:22 pm
Is the beta also available for the Linux 64 bit Command line version?
PostPosted: Tue Aug 17, 2021 3:58 pm
for B38, the input buffer for input 2 constantly depletes, cannot be corrected with any setting.
also, please bring back the detailed MPX spectrum drawing.
PostPosted: Tue Aug 17, 2021 4:55 pm
Hi, I've just fixed the MPX spectrum drawing. Something broke when I fixed another issue (disabled waveforms were enabled again after restarting).
About input 2: I don't see any problems with it here, so I need more info. Is this a new problem, do you know if it occurred with older versions? And does the same sound card work if you select it as the first input sound card?
No, but I expect that we'll have a new release within a few days. If no new bugs are reported...
PostPosted: Tue Aug 17, 2021 6:18 pm
i will provide the relevant information shortly after i perform some various tests as you requested but at the moment, i am working.
this is using 64bit beta 38 stand alone.
the issue did not occur with beta 37.
PostPosted: Tue Aug 17, 2021 6:53 pm
  • Rewrote sqrt(x) to x * 1 / sqrt(x), which is faster
rofl
PostPosted: Tue Aug 17, 2021 7:10 pm
O, that's very odd. I haven't touched the I/O code at all since 037. Just to make sure, can you also verify that 037 is really still ok on your end? It might be broken due to a Windows update or something like that.
