Post new topic  Reply to topic  [ 239 posts ]  Go to page Previous 19 10 11 12 1324 Next
 Post subject: Re: StudioOne HD / FM
PostPosted: Sun Apr 25, 2021 10:04 am
I listened to your preset for a long time. It seems to me that there is a little lack of "transparency, lightness". The sound is a little dull, as if through cloth. What do you think?
PostPosted: Sun Apr 25, 2021 5:02 pm
Might be, however is redesigned bands in MB, and currently making them to sound as close as possible to previous MB, and in same time to fix things like that.
PostPosted: Mon May 03, 2021 4:48 pm
Will there be an update to the StudioOne HD/FM preset using the changes and improvements in 9.70?
PostPosted: Mon May 03, 2021 6:30 pm
Yes. i changed lot of things too.
PostPosted: Mon May 03, 2021 6:34 pm
Cool! Thanks for your hard work!
PostPosted: Mon May 03, 2021 7:36 pm
That changes in your preset are included in 9.70 already?
https://fmfeeling.com
PostPosted: Mon May 03, 2021 8:18 pm
Not yet.
PostPosted: Sat May 08, 2021 6:15 pm
Could this possibly relate to input levels / noise gating? If you disable the noise gate do you notice any difference?
PostPosted: Sat May 08, 2021 8:48 pm
Noise gate? It really depends on your input level Current settings is just fine around -6dB (-12 to -0) input, but for lower inputs you need to set lower thresh probably. So, there is no proper level for noise gate. Also AGC gate, since it reacts on input level too. So it can be dull on some very low inputs if noise gate is not set right.
Anyway, preset is not pushed with highs too much. It's maded to be open, big, and to have some dynamics especially on highs.
PostPosted: Mon Jun 14, 2021 10:33 pm
Bojcha, are you still cooking something yummy up for us fans of your amazing presets??
