New plan:
- Switch back to 5.00 type of filtering, but based on ITU 1770 levels instead of RMS levels
hmm .. I thought that I suggest something like that, but is that we already have when Smoothing is turned off ?
Multiply the equalizer levels of the last 2 bands by 0.98; 3. If you are using 'Before multiband', also multiply the Soft Limit values of the last 2 bands by 0.98.
This only seems to occur when the lowpass filter is used...
Yes, Lowpass rises that highs near selectend frequency by lowpass and you can easy internaly fix that by EQ!
BUT, Lowpass is before multiband, and you can see when you turn on lowpass at 15kHz, last band is rised! Maybe is better to set soft limit lower insted EQ. But again diferently seted Lowpas need different settings of last two bands (EQ or soft limit)
15kHz lowpass - should be flat
i know some processors have "steps" for lowpass/highpass -15, 15.5, 16, 16.5, 17 kHz
And for every step differently seted EQ or whatever
edit: i just checked...
For 15kHz lowpass you need to set EQ (after multiband) 9th band -0.86 and 10th -2.26 that is for LIMIT mode in Multiband
For Compress mode -0.86 and -1.91
