Post new topic  Reply to topic  [ 209 posts ]  Go to page Previous 19 10 11 12 1321 Next
PostPosted: Tue Aug 08, 2017 7:32 pm
8.41 BETA045. Only a few small fixes this time.
The new version is really much better now. Are apparently only small changes which give a generally good picture.
Edit: A tiny little perhaps. Could you perhaps add a gate in the new spectrum module? Then you could make the control even better. Because in very old music at almost nonexistent heights would be great!
PostPosted: Fri Aug 11, 2017 3:41 am
I dont even know how to use AGC2 without AGC1. Should be a new AGC instead anyways?
Where is that Final Limiter?
edit
found it. Ow it works with old clipper only, atlaest it looks like.
PostPosted: Fri Aug 11, 2017 11:59 pm
In the next version it will be switchable between old and new mode, and some of the settings (side chain, window, ratio, threshold, drive) will be shared.
PostPosted: Sat Aug 12, 2017 1:42 am
8.41 Beta 27. Auto-start is NOT flagged, yet the program starts on reboot. Stereo Tool is not in my startup folder.
Win7
PostPosted: Sat Aug 12, 2017 12:54 pm
8.41 BETA046.
Warning: The new AGC now shares several settings (Drive, Threshold, Window, Ratio, ITU1770, Paramertric eq) with the old one. This means that if you were using the new AGC in the previous beta's, you will have to reconfigure it.
Windows stand alone: http://www.stereotool.com/download/ster ... 41-046.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 41-046.exe
VST: http://www.stereotool.com/download/vst_ ... 41-046.dll
- Share PEQ, attack/release?
- Move Spectrum Control and new AGC out of "Experimental" tab, and allow licensing. --> Button to buy it will be added to the website on Monday!
- Show Spectrum Control and new AGC in bottom display
- Optimize limiter
- Allow using bass distortion in bass clipper when used for final limiter.
- Limiter display freeze
- Add pre-AGC classical music thing
- MicroMPX add display for packet reception todo add reset packets, fix timing, show current playing position
- Add "Advanced Dynamics" to license overview screen
- Finish pre-AGC classical music thing
- SST: Make list of new ID's
- 64 bit Hard Limit is working again
- Meter for Limiter is no longer frozen.
- 9sg - update to latest code
- Old web interface bug fixes
- 9sg 1 thread.
- Add bass clipper + final limiter for testing for streaming, to figure out once and for all if it's useful or not.
- Final limiter: Make speed depend on amount of bass clipping.
- Final limiter: Fix going though chunks.
- Spectrum Control: Abrupt Change Protection could overract because it ignored certain settings.
- Spectrum Control: ACP can overreact!
- Spectrum Control: Why is kick so fast?
- All compressors: Attack/release behavior in the new RMS mode was wrong, now fixed. Result is more consistent and movements are less sudden.
- Compressor inverse-Covfefe
- AM stereo downmixer 9
- Show backup input is active - change color of input level meters
- Final limiter: Put in separate file, so I can test it separately.
- Final limiter: Make own settings page. Lots of settings needed...
- Final limiter: Make it work for Quality != 100%, Latency != 4096
- MicroMPX web interface
- Fixed crash when changing number of bands in Spectrum Control.
- Add Parametric EQ to AGC 2
- RDS: 8 character words with <| go wrong
- RDS: Empty fields - remove?
New "Experimental" section, containing:
* NEW AGC
* New Spectrum Controller (replacement of Power Bass/Power Highs), adjusts the spectrum BEFORE the AGC, without affecting dynamics or loudness.
The Analog compressors now have new "Max ratio" and "Max ratio at" settings to have dynamic ratio's depending on how the amount of attenuation.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- ACP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- SC ACP: Speeds should not affect it!
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- GUI doesn't work in some of the versions of 046
- Disable Pre Limiter display in limiting mode.
- 64 bit: Crash reported
- Update RDS encoder to Mathijs' filter.
- NAB! LW!
- ADYEN
- Linux version crashes in latest Debian (Jack compatibility issue?)
- RDS: Make note in help about shared drives. Also send to Omnia.
- Allow moving equalizer between MB's
- Allow moving BB before last MB
- MicroMPX web interface version: Make sure that all ranges are correct and everything is stable when changing settings.
- SST: Ohio Valley and Blue Steel use Pre Amp
- SST: Couple Hard Limit to clipper on/off
- Old web interface: Text color in check boxes and buttons doesn't update
- Old web interface: Original right load can be messy. Load left first?
- Old web interface: Fix display of vu meters, also for SC
- Web interface reuse old numbers
- Old web interface avoid reload OR pass GUID
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes.
- Try new stereo widener idea
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- Decide what to do with "Clip bass only (EXPERIMENTAL)"
- ladspa? r.co
- SST: Make it switch to backup input when the normal/FM signal switches.
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Fix Bass boost frequencies in SST
- Make compressor with alternative ratio implementation
- Classical music compressor
- uMPX web interface
- Test clipping
- NAB
- Improve UECP ASCII mode for Magic RDS (just handle \n's inside strings)
- RDS UCEP: Put a timeout on the fallback to default settings. Some programs close the connection immediately.
PostPosted: Sat Aug 12, 2017 1:05 pm
Beta 046
Only a white screen
PostPosted: Sat Aug 12, 2017 1:06 pm
I have the same problem on win 10 64b with winamp dsp version
PostPosted: Sat Aug 12, 2017 1:17 pm
Same here with Stand alone 64bit. The GUI is completely missing.
PostPosted: Sat Aug 12, 2017 7:29 pm
:lol: :lol: that's what happend when you not test a new build... ;), but What is going wrong with the last few months?..Every build has problems :!:
Garbage in is Garbage out !
PostPosted: Sat Aug 12, 2017 8:23 pm
It worked fine here last night..... I'm not at home right now but I'll try to reproduce this issue as soon as I get home.
There is a change in the GUI (because there's an extra option in the left menu I had to make the top panel a bit higher, and because of that also the minimum window height). I've tested a lot of things yesterday, including making sure that a too small window from the previous version is automatically made bigger etc. Everything appeared to be ok.
