Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Mon Apr 04, 2016 11:54 am
Are there any noobs that actually buy presets? I mean - If you own a processor, you use it, you learn it, pick up some "generic built in preset", test it... blah blah blah - in the end - you can set it up - right?
to me buying presets is... unthinkable :D
PostPosted: Mon Apr 04, 2016 12:03 pm
You can modify the preset for less distortion ( if found :) on new version ( v2 ) but you cannot distribute it or re-sell it as is or modified.
Says who :D? Is it mentioned somewhere in the license? Does the preset come with the license agreement or invoice :D?
PostPosted: Mon Apr 04, 2016 1:01 pm
1 ) A preset can make a processor sound GOOD or BAD .
This is the big problem for sound processor makers ( Leif, Hans, Bob, Franky )
2) In order to make a preset for a sound processor it can take MONTHS of testing.
Sometimes sound processor makers or preset makers rely on feedback from listeners or other engineers and make their presets or software even better . In my opinion this is the reason Hans has the betas OPEN for testing and feedback.
If something takes you HOURS or MONTHS of work you can make money from it .
Without presets , processors would be just an imput and output with default settings.
It's like food :) You can make it taste better or ...worse :)
If i sell this LOUD preset i would sell it for more than 900 euros.
It is many many hours of work and it would be bad if someone publishes it after paying it.
PostPosted: Mon Apr 04, 2016 1:06 pm
Hehehheeh!
Indeed the preset in Omnia is veryyyyyyyy loud and clean !
I wish i could make something like that :)
Probably the V2 preset i made can be for "multi millions of dollars ..or euros " commercial radiostations!
Check it out . v2 is here ( with no distortions ) just ..faaaaaaaat and loudddd :)
http://stream.cretanservers.gr/fmbroadcast
PostPosted: Mon Apr 04, 2016 1:46 pm
I was asking about something else - what would physically prevent others from reselling ;) Read it again.
And for the record - yes, the stream is perfect indeed:
Worst ever!
PostPosted: Mon Apr 04, 2016 2:25 pm
Hehehheeh!
With no distortion you say :D
first of all - disable preemphasis in the stream feed (looks and sounds as if it was on), also clipped bass and soooo many bad things I don't even want to write about.
PostPosted: Mon Apr 04, 2016 2:32 pm
1) preemfasis is needed for feeding a transmitter site using sattelite internet.
It is the final output WITHOUT mpx advanced clipper .
With the advanced clipper it is better and even louder
2 ) Hans will give the ability to encrypt presets if needed soon.
Hope this protects the copyright for all those people who spend hours on creating a preset and want to sell it .
This preset took me months to make it.
Life is short :)
PostPosted: Mon Apr 04, 2016 2:35 pm
Life is short :)
Why would anyone want to buy this? And even if there are some hearing-impaired desperates out there who would want this - those poor listeners' lives will indeed be very short.
PostPosted: Mon Apr 04, 2016 2:37 pm
trust me ! ,
Already there are 3 radiostations that took the latest version of my preset and 1 individual.
PRESETS ARE THE HEART ,
STEREOTOOL is THE BRAIN !
There which is what?
