Post new topic  Reply to topic  [ 13 posts ]  Go to page Previous 1 2
PostPosted: Tue Aug 21, 2018 5:38 pm
# Input to Processing
input = radio
# Processing
process = mksafe(pipe(process='/home/path_to_stereotool/stereo_tool_cmd_64 - - -s /home/path_to_stereotool/preset.sts -q -k "<STEREO_TOOL_LICENSE>"', input))
# Processing to Output
output = process
Hi, I tried the above code, I works but the following problem occurs :
Everytime when new track is started, I get a "crackling/digital click" sound for very short time.
It looks like for every track, a new stereotool process is created. The annoying crackling sound is produced at the start of the new procesing job. This would explain the click, but is there a possibility to get rid of it ?
here is an audio clip of the problem --> https://instaud.io/2AsA
PostPosted: Thu Jan 28, 2021 12:16 am
The annoying crackling sound is produced at the start of the new procesing job.This would explain the click, but is there a possibility to get rid of it ?
An old thread, still useful for me :) It was difficult to understand the way how liquidsoap sends the "pipe" stream.
The simple answer is: "with metadata"
That's why stereotool produce strange clicks and cracks. An easy workaround is kill the metadata BEFORE the stream goes to stereotool:
radio = drop_metadata(radio)
and everything is perfect - except metadata - but this is another question.
PostPosted: Mon Feb 01, 2021 9:22 am
Just use
replay_delay=1.0
in the pipe method and you should be good to go.
You will get your metadata and you won't have "strange clicks and cracks", no need to just drop metadata as a workaround.
