Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 92 posts ]  Go to page Previous 1 2 3 4 510 Next
PostPosted: Tue Dec 08, 2015 12:49 pm
Hans, from beta 1 to beta 4 we have more memory allocated at about 40mb more memory
PostPosted: Tue Dec 08, 2015 12:58 pm
It`s not worth from 14.5 to 14.3 to add this option.
Well, I said so far. I expect that the effect can be a lot bigger in the end. And there are other reasons to add this.
Also i don`t like that digital and analog MB share one values. I need to change the analog ones , but when i return to digital - i must return the values too. It`s not good for testing or make a preset, because every time i must change many things to make it. For direct compare is not good too.
So intead of this , i propose to make values separate in MB. For the MB2 (analog only) one everything is clear
I actually did it this way to make it easy to convert an existing Digital preset to Analog mode. Normally you would pick one of the two types (I would suggest Analog!) and then start working on it.
PostPosted: Tue Dec 08, 2015 1:32 pm
When at last is corrected the transfer of VST plugin parameter? You had once written, that you want to resolve this the year or in the course of the year. Otherwise, use the PNR function is still not possible. It would be really great if it works at last.
Thank you in advance!
Workaround is working now!
PostPosted: Tue Dec 08, 2015 1:33 pm
O. I know I allocate a lot more memory in the 1st beta (compared to the latest release) but 40 MB between the first and last beta makes no sense. Will check what's wrong.
Edit: Don't see much difference between BETA002 and BETA007 here? Less than 1 MB. How did you test, and which version (plugin, stand alone)?
Edit #2: Even the difference between 7.83 RELEASE and 7.84 BETA007 is less than 1 MB.
PostPosted: Tue Dec 08, 2015 6:03 pm
That's fine!
But, these is unfortunately only a workaround. Now if someone uses the plugin, for example, in applications such as Adobe Premiere, then this information will be lost when you "save the project". Of course, you could save the Stereo Tool settings as sts-file. These settings could then charge again after the opening of the project. But this is very error-prone and does not solve the actual problem. Incidentally, the software "Melodyne editor" also has very large amounts of data that must be stored. Here there is no problem. Therefore, there must be some way to make that even with Stereo Tool. The problem itself is now known almost a whole year.
Please Hans check again all the possibilities that exist. There must be a good solution here, since it is indeed the future be more and more parameters.
PostPosted: Tue Dec 08, 2015 6:15 pm
The good solution is to store parameters not by enum values but the same way as the .sts file, but as VST parameters. The disadvantage of doing that is that it makes it impossible to automate things in VST hosts, so I'm not really sure if this is a good idea. Saving them the way I save the others will cause crashes in some hosts (I've already seen issues in the Mac version that I had to work around).
It can (and probably should) be done, but it will take more effort.
PostPosted: Wed Dec 09, 2015 12:57 pm
I mean between 784.02 and latest... Standalone version.
PostPosted: Wed Dec 09, 2015 2:32 pm
Tried it again, 7.84-002 and 7.84-007 both use 131 MB.
PostPosted: Wed Dec 09, 2015 2:42 pm
7.84-001 ? 7.83?
someone uses less. it was 94 and after i update goes to 132
PostPosted: Wed Dec 09, 2015 2:47 pm
7.84-001 ? 7.83?
7.70: 192
7.73: 130
7.83: 131
