Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Wed Nov 04, 2015 5:10 am
Analog input only. Sorry, by digital output what I really mean is MPX into an FM transmitter.
PostPosted: Thu Nov 05, 2015 8:46 pm
It all seems to be running well, meters for both analog and digital input are OK but still no output via RCA/BNC.
SHould I try disabling the analog output in favor of FM/digital/MPX only? Does ST ever default to one or the other even if I route the audio differently in the Marian Trace Alpha?
PostPosted: Fri Nov 06, 2015 1:34 am
I am just completely confused now. What is FM/digital/MPX? MPX is almost always analog (only a few transmitters supports MPX over an AES/EBU digital connection, but the Trace Alpha doesn't have AES/EBU so you can't mean that).
And how are you routing things in the Trace Alpha?
PostPosted: Fri Nov 06, 2015 4:15 am
My apologies, Hans, it is my naivete which is confusing you, totally my fault.
Yes, I realized today that MPX is analog; the Marian Trace Alpha has two sets of outputs, 1/4 TRS paired for analog, and RCA paired which I have been calling "digital" but really what I mean is different analog/MPX. Again, sorry.
I have to go back and look at the MTA hardware to see if all my internal jumper settings are OK, I did NOT change any, assuming that default settings were good enough...
Routing: Input from Analog 1-2
Normal Output: Play 1-2 to ASIO Output 1-2
FM Output: Play 1-2 to ASIO Output 3-4
Trace Alpha Outputs: Analog: Play 1-2
S/PDIF Audio: Play 3-4 (analog)
PostPosted: Sat Nov 07, 2015 9:30 pm
Ah, a big ST thank you to Bob Hawkins who helped me through a major stumbling block: The MTA composite output is via the 1/4" outputs, NOT the RCA outputs as I was expecting.
Next challenge will be to improve the deviation - only getting 32Khz on my first (brief) test.
Thanks again BOb!
PostPosted: Sun Nov 08, 2015 3:13 am
I usually use 9-10 for asio on Marian, since it's on separate route ;)
PostPosted: Sun Nov 08, 2015 5:17 am
Interesting - output right?
PostPosted: Sun Nov 08, 2015 3:52 pm
http://i.imgur.com/ePFcv0I.png
PostPosted: Sun Nov 08, 2015 4:17 pm
thanks! It helps me to see others' setups...
PostPosted: Mon Nov 16, 2015 3:04 pm
OK, I've got ST in the airchain (community radio LPFM).
Marian Trace Alpha, sending FM MPX via MTA output 2 to transmitter.
MTA mixer is input on Analog 1-2 then Play 1-2; output to Analog.
Right now, I have the same FM output on MTA output 1 for streaming audio... but haven't quite figured out if/how to send "Normal" Output to output 1 instead (sound is a bit bright, probably the pre-emphasis?)
Should I be looking at an ST setting or a mixer setting or both?
