 Post subject: Re: RDS features
PostPosted: Mon Aug 17, 2015 11:20 pm
I think there should be separate box fro RT+ texts.
PostPosted: Mon Aug 17, 2015 11:48 pm
That's not how it works. You send a RadioText, and indicators where an RT+ field starts and how long it is. So, this is the simplest way I could think of to do it.
RT+ works,
but you really should update help with this one :P:
How to use RT+ in RadioText
Put \+xx before and \- after an item
where xx is an RT+ type number (00-63).
Instead of a number you can also use the codes
WW or UR for an URL (type 29)
AR for Artist (type 04)
TI for Title (type 01)
So for example:
Now playing \+ArMadonna\- - \+TiLike a Virgin\-
You can use at most 2 codes. For now, codes are transmitted for ALL the texts, so this only works properly if you have a static RT text. I might change that later.
Help text is getting outdated indeed... I will update it but probably after the IBC (I also need to finish some things for Omnia before the IBC starts).
PostPosted: Mon Aug 17, 2015 11:50 pm
Yes but then in main line you can just put one "sign" that read from that box (?)
