Post new topic  Reply to topic  [ 12 posts ]  Go to page Previous 1 2
PostPosted: Sun Jun 28, 2015 3:09 pm
I have - a while ago - already removed all the presets that used the Classic Multiband
Too be honest, I havent switched my presets because the new multiband is simply too complicated for me. :) The old one I understand and I can tweak on one dialog.
And I really dont know if after it I have a better sound if I take the time to try and convert the old multiband settings to the new one. If there could be an automatic conversion from old to new multiband would be nice.
In my "Remaster" preset I often use the voice protection setting of the old multiband to fine tune the dominance of the singing voice in a track. I cant see this feature with the new multiband?
PostPosted: Thu Oct 08, 2015 11:27 pm
The second Multiband is indeed complicated, but if you work with it for a time, you just hear the benefits of it, with the digital multi you missed some signature, with multi2 you come close, I assume it's not finished yet and still under construction? I made some presets with really great punch in the lower frequencies which were filtered out with multi1. Especially in the range between 250Hz and 500Hz were some serious deviations in the past (not only ST has this problem, also Breakaway has this), so slowly we're getting there I'm sure.
