Post new topic  Reply to topic  [ 328 posts ]  Go to page Previous 1 2 3 4 533 Next
PostPosted: Mon Nov 24, 2014 8:48 pm
Windows stand alone: http://www.stereotool.com/download/ster ... 52-002.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 52-002.exe
- PNR analysis data is saved now
PREVIOUS:
- Added PNR Noise & Hum
Note: If you change the Latency or Quality setting or the number of audio channels, the filter is turned off! Analysis is specific to those settings.
PostPosted: Mon Nov 24, 2014 10:16 pm
It's still enabled when "reset all/prn settings" and Turns ON with any preset loaded.
PostPosted: Mon Nov 24, 2014 10:51 pm
Ow. I guess I turned it on by default for testing purposes before I added it to the GUI. Will fix that in the next version. (If you don't do an analysis, it doesn't have any effect).
PostPosted: Tue Nov 25, 2014 7:55 pm
Next bèta (tonight) has some small changes that should make the output spectrum of Advanced Bass Distortion Protection flatter. I haven't really changed much but some filter frequencies have been moved a bit to reduce holes in the spectrum.
PostPosted: Tue Nov 25, 2014 8:29 pm
Great.
Do you mean you test my test sound that i posted on previous version thread ?
PostPosted: Tue Nov 25, 2014 9:26 pm
Great.
No this is a completely different issue. I'm talking about the spectrum (when you feed it pink noise). There were some bumps in it, which is bad. And the new version sounds fuller and more open to me (there's also slightly more intermodulation distortion, but my first impression is that this is really better).
Will upload it in a moment!
PostPosted: Tue Nov 25, 2014 9:40 pm
Windows stand alone: http://www.stereotool.com/download/ster ... 52-003.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 52-003.exe
- Advanced Clipper: Advanced Bass Distortion Protection (ABDP): Drop in output when strongly clipping around 2600-4000 Hz is reduced.
- Advanced Clipper: ABDP: "Smooth Slide" slider added to make transition between deep bass (clipped) and less deep bass smoother. There used to be a drop upto the 2nd configured bass frequency, with this switch enabled the drop is smoothed (maximum at 1st configured bass freq, gone at 2nd). Result: Warmer, more open, less 'restrained' sound. But probably also a bit more intermodulation distortion. (which might be fixable by changing the frequencies a bit). (*)
- Display FM lowpass frequency at bottom when FM output is used.
(*) If you don't hear the difference, try this: In ABDP, set the 2 bass frequency sliders both to 0. This will completely kill the bass. Now, turn the Smooth Slope setting on and off. The same effect is also present at normal settings, just less extreme.
PREVIOUS:
PostPosted: Tue Nov 25, 2014 9:44 pm
hmm , distortion ? I don`t like any type of distortion :(
Will be good to know how with new sliders/options i can make it like they are not present .. I mean to be like or till this beta. Will test but i don`t like dostortion.
PostPosted: Tue Nov 25, 2014 9:46 pm
Just try it out... There could be more distortion but based on my (very limited) tests so far it's very little, and the sound does get much warmer and more open.
And you can turn that new setting off.... and if you only clip a bit there's probably no difference at all.
PostPosted: Tue Nov 25, 2014 9:49 pm
Alright, i`ll test it to see :)
