 Post subject: Re: [RDS] Radiotext+
PostPosted: Sat May 16, 2015 3:56 am
See the other post - I've described it there!
PostPosted: Sat May 16, 2015 5:42 am
Works great! Dynamic support will be awesome. I push updates using a script in Linux so that will bge a great addition. (This test was done in Windows 8.1).
PostPosted: Sat May 16, 2015 12:39 pm
Great! What do you mean by dynamic support? You can read the now playing info from a file already.
PostPosted: Wed Aug 19, 2015 3:05 pm
Hello Hans.
Congratulations on the stereo tool project.
I am testing the RDS Radio Text Plus Now Playing from a .txt file and not working. My nowplaying.txt file template is:
\+Ar$artist$\- - \+Ti$title$\-
In Stereo Tool RT screen it is shown this way:
Now playing \+ArPharrell Williams\- - \+TiHappy\-
If I put it in the RT command line it is shown correct:
Now playing Pharrell Williams - Happy
What can I do?
Thanks for your time and sorry for my english.
PostPosted: Wed Aug 19, 2015 10:05 pm
You can include a file using \R or \r or \F of \f. You're probably using \R or \r, replace that by \F or \f. \F reads formatted text, \R reads raw text and just displays it without parsing it.
PostPosted: Thu Aug 27, 2015 5:04 pm
Hi Hans. Thank you very much for your reply. Yes I use the \R command :roll: . I will try \F or \f. :)
