Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: V0rs1S by GAP
PostPosted: Thu Sep 11, 2014 10:07 pm
This seems like a really nice all-purpose preset (as opposed to being specifically designed for web radio stations only). Out of curiousity, any way to make use of "Natural Dynamics"? I noticed it was disabled in your preset. I know it's a premium feature but I wondered if it can be configured for those of us that did buy it.
PostPosted: Fri Sep 12, 2014 1:49 am
I rarely comment presets...
It sound too much thin. Too much highs. If i just level bands to proper level things are much better. So it has potentinal.
PostPosted: Fri Sep 12, 2014 5:51 am
Thank you very much, my preset always consider just what I said.
Regarding the "Natural Dynamic", usually not habilito because my PC does not allow me to adjust fluidity. :(
Like I will review this in next version of the preset. ;)
Bojcha thanks, your comment will very adequate.
It is true what you say, now that I hear it I notice the error !!! :oops:
I leave a new version where I correct the error ... I hope. ;)
GAP_V0rs1S_v0.7.sts [62.28 KiB]
Downloaded 427 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Sun Sep 14, 2014 4:19 am
@djnforce9: Enable Natural Dynamics (5-band, which was able to use my pc uncut). ;)
@All: Some spectral correction, smoothing the highs and a bit more dynamic. :idea:
GAP_V0rs1S_v0.8.sts [62.32 KiB]
Downloaded 456 times
by GAP
PostPosted: Mon Sep 15, 2014 6:55 pm
Better!!! ;)
PostPosted: Mon Sep 15, 2014 8:59 pm
Better!!! ;)
Thanks! :)
by GAP
PostPosted: Fri Oct 03, 2014 5:20 am
Well I think this is the latest version for this preset. ;)
If you think something is missing or spare, do let me know. :)
GAP_V0rs1S_v0.9.sts [62.33 KiB]
Downloaded 506 times
by GAP
PostPosted: Fri Aug 14, 2015 7:42 pm
I really like the MB1's meters dance in your preset and that's why I modified to my own taste.
Quite modified version now with bumpy AGC, MB2 with a default tweak and the SB responsible for the bass mainly.
Loudness and Bass level set to your own taste.
Modified on Urban and Dance music.
Gap_V0rs1S_Force_Groove.sts [84.06 KiB]
Downloaded 394 times
PostPosted: Mon Aug 17, 2015 1:18 pm
Re modified to a "normal" preset.
Gap_V0rs1S_Force_Groove_2.sts [84.27 KiB]
Downloaded 432 times
PostPosted: Tue Sep 29, 2015 9:30 am
Good morning. Great sound the version Groove2. Its possible have a little bass punch modified for me? Or what to edit for do a bass punch for my do it yourself? Thanks
