Post new topic  Reply to topic  [ 68 posts ]  Go to page Previous 1 2 3 4 57 Next
 Post subject: Re: Stereo Tool 7.43
PostPosted: Wed Jul 02, 2014 2:00 pm
Cause of VLC problem in 64 bit version is found. Will fix it asap.
Great! Please speak up if I can provide you with further relevant information.
PostPosted: Wed Jul 02, 2014 2:44 pm
Problem was that there's a place where I have to send some memory addresses to VLC. As text strings...
I used some example code from the VLC site that uses "%ld" as formatting to encode a memory location, treating it as a 'long int'. I assumed that since int is 32 bits, long int is 64, and because I found this example code on the VLC Wiki-pages I never checked it, but it turns out that it's also 32 bits... For 64 bits I need to use 'long long int', or "%lld".
This caused an invalid address to be present inside VLC. When VLC attempts to call a Stereo Tool function it actually calls a random location which causes a crash - in VLC, and completely outside of Stereo Tool control, so I cannot show a nice popup window myself.
Problem seems fixed now (I still have to check if receiving streams works fine, but sending is ok); will update it on the site asap.
PostPosted: Wed Jul 02, 2014 3:19 pm
Major bug in the AGC
In 3 bands mode, moving the slider "reduce band 3 further if vol gets above" to 0% followed by any other value, completely locks up band 3 requiring a full restart of the program to bring it back to normal.
Also, major bug with the flat tops/singleband
With flat tops and singleband enabled (the one after the bass boost), playing with the flat tops slider from the bands section in multiband, 9 times outta 10 is gonna completely screw up singleband, again, requiring a full restart of the program to get things to normal.
PostPosted: Wed Jul 02, 2014 3:39 pm
Confirmed, these settings should not go below 1%. (What happens is basically that their level is set to 0, and when the level goes up the speed is relative to the level. So if the level hits 0, it will never go up anymore).
Unable to confirm that here.
PostPosted: Wed Jul 02, 2014 4:11 pm
64 bit stand alone version is updated - please redownload and test if it works now. (Make sure that you don't get a cached copy of the previous version).
PostPosted: Wed Jul 02, 2014 4:56 pm
Probable bug : the MPX frequency display window on AM is frozen. Changing the low pass filter setting from 10khz to 1khz results in no change on the screen.
PostPosted: Wed Jul 02, 2014 5:55 pm
Hm, I have seen it work before but now I can't get it to move either. So indeed a bug.
PostPosted: Wed Jul 02, 2014 7:52 pm
Post amplifier not working.
PostPosted: Wed Jul 02, 2014 9:38 pm
Great! The new version doesn't crash when enabling Normal Output for VLC streaming.
Less than 24 hours after I reported the issue, you fixed the issue and uploaded a new version - that's just so great! 8-) Thanks!
PostPosted: Wed Jul 02, 2014 10:05 pm
Check out the video
http://www27.zippyshare.com/v/74016281/file.html
