Post new topic  Reply to topic  [ 12 posts ]  Go to page Previous 1 2
 Post subject: Re: SoundMAX HD Audio
PostPosted: Thu Jun 25, 2015 9:31 pm
Hm...... One thing that might help is, if you have the Volume setting in Stereo Tool set pretty low, to instead use the Windows volume control (which probably reduces the hiss) and only use the Volume slider in ST for fine control.
PostPosted: Wed Jul 01, 2015 12:02 am
@bocha : most of my realtek card support 192khz in/out.
@kyanox : try to do most of the gain reduction in your transmiter. Don't turn ST down 12db if you want 12db of gain reduction. Do it from your transmitter.
@hvz : i never got an soundmax chip to work with mpx. And i never like pd the way they sounded. (Filters are allover the place and not consistend from card to card)
My radio station
http://amradio.ddns.net
