Post new topic  Reply to topic  [ 15 posts ]  Go to page Previous 1 2
 Post subject: Re: Input level tweak
PostPosted: Sun Mar 23, 2014 8:02 pm
OK... Thanks for the input. I'll download the one you recommend (J-Type) and test it on another computer. And, I'd be willing to try the one you haven't built yet, too. Don't rush on my account.
I need loudness, declipping of the source material and openness with punch. J-Town sounds like it'd be a good choice.
Did you process "I Will Follow You" with J-Town?
PostPosted: Mon Mar 24, 2014 4:47 pm
J-Type sounds nice! I'll have to try it on the air... and that'll have to be after midnight one night this week.
PostPosted: Mon Mar 24, 2014 7:47 pm
Ok let us know..
PostPosted: Tue Mar 25, 2014 9:44 pm
O..
I can tell you this. Don't use that preset :)
That one uses old multiband and it was maded to be answer fro upcoming Omnia.11 in that time.
Depend on what sound you like I can recommend "J-Type" with bit more pushed Advanced Clipper.
That should give you much details and competitive loudness.
If you are looking super compressed preset then i cant help much.
Also, if you are interested, i can give you my latest preset with 6 bands where everything is maximaly contolred from multiband. Yet, i would need to build FM version - that should go quick.
I would like that preset, please... Bojcha.
For the Multipath Clipper, what is optimal for the level? I see it defaults to 200%
PostPosted: Thu Mar 27, 2014 7:53 pm
I've been running a modified J-Type for the last 24 hours. Still tweaking it. Definitely nice and loud!
