Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: X-Mas Sensation
PostPosted: Mon Dec 23, 2013 2:22 pm
Great preset! Also for non-Christmas music ;-)
PostPosted: Mon Dec 23, 2013 3:43 pm
Please use only Stereotool and Edcast.
Ok some help required then as i added the stereo tool as a dsp plugin via breakaway which also has the edcast plugin and output
I basically need stereotool to pick up my main feed in to the pc from mixer and process and send to edcast?
Help?
Matt
Really simple.. you need..
- Stereo Tool Standalone
- VAC
- and Edcast
Set input your soundcard, and output VAC to Edcast.
PostPosted: Sat Dec 24, 2022 3:35 pm
By request i added 2022 version.
PostPosted: Mon Dec 26, 2022 10:40 am
i use dsp plugin make that diverens whif the stand allown sound
PostPosted: Mon Dec 26, 2022 10:44 am
Should not at all.
PostPosted: Thu Dec 29, 2022 1:43 pm
Hello. I've been using this preset for the third day. I think this is the best Stereo tool preset so far. On all types of speakers and headphones, the sound is of equal quality. I would like to see this preset in the list of Stereo tool presets.
PostPosted: Wed Mar 22, 2023 6:35 pm
We are using every day on our web radio and it is great.
https://www.rete2000.it/diretta-live/
I prefere this instead of your bigflexHD.
It seems more “bassy” and loud :)
We use it with autoEQ enabled. Is it ok?
Have you plans to upgrade for 2023? :)
PostPosted: Thu Mar 23, 2023 9:04 pm
Your sound is very good. Please can you tell me what changes you made to the X-Mas Sensation preset?
PostPosted: Fri Mar 24, 2023 5:29 am
Thank you for the reply.
We use xmas sensation with declipper on and auto eq on.
We are using Stereotool as vst plugin with mbstudio radio automation.
PostPosted: Sun Aug 13, 2023 5:59 pm
Hi, will you plan to do a 2023 upgrade of this great preset?
