Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Mon Oct 26, 2009 3:21 pm
Don't worry - I won't be able to release anything much sooner than that because I have to do some tweaking of settings. I think it will probably be tomorrow - or very late tonight (past midnight, way more than 9 hours from now).
PostPosted: Mon Oct 26, 2009 11:23 pm
As always, it is a work in progress.
Ignore the stuff below (I left it for progress) (see next post):
[Common]
Pre amplifier=5
Post amplifier=1
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.75
Extra loudness - Max Punch peak=0.75
Bass protection - Enabled=0
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
Process for low latency=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=3.299999952
Relative noise gate level - Band 4=1.352941036
Relative noise gate level - Band 5=2.333333254
Relative noise gate level - Band 6=2.508771658
Relative noise gate level - Band 7=3
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=1.25
Maximum value=0
Attack speed=0.00000137
Decay speed=0.999000013
Above Top Limiter=1
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=25000
Maximum volume - Band 2=10000
Attack speed - Band 1=0.000002374
Attack speed - Band 2=0.000002374
Decay speed - Band 1=0.002375506
Decay speed - Band 2=0.002375506
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Very high quality enabled=1
Maximum volume - Band -1=6100
Maximum volume - Band 0=6150
Maximum volume - Band 1=6250
Maximum volume - Band 2=5600
Maximum volume - Band 3=4450
Maximum volume - Band 4=3700
Maximum volume - Band 5=3350
Maximum volume - Band 6=3050
Maximum volume - Band 7=2800
Maximum volume - Band 8=3400
Attack speeds linked=1
Attack speed - Band -1=0.000003944
Attack speed - Band 0=0.000003944
Attack speed - Band 1=0.000003944
Attack speed - Band 2=0.000003944
Attack speed - Band 3=0.000003944
Attack speed - Band 4=0.000003944
Attack speed - Band 5=0.000003944
Attack speed - Band 6=0.000003944
Attack speed - Band 7=0.000003944
Attack speed - Band 8=0.000003944
Decay speeds linked=1
Decay speed - Band -1=0.000139355
Decay speed - Band 0=0.000139355
Decay speed - Band 1=0.000139355
Decay speed - Band 2=0.000139355
Decay speed - Band 3=0.000139355
Decay speed - Band 4=0.000139355
Decay speed - Band 5=0.000139355
Decay speed - Band 6=0.000139355
Decay speed - Band 7=0.000139355
Decay speed - Band 8=0.000139355
Above Top Limiter=1
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=1.500000238
Relative clip position - Band 0=1.500000238
Relative clip position - Band 1=1.500000238
Relative clip position - Band 2=1.500000238
Relative clip position - Band 3=1.500000238
Relative clip position - Band 4=1.500000238
Relative clip position - Band 5=1.500000238
Relative clip position - Band 6=1.500000238
Relative clip position - Band 7=1
Relative clip position - Band 8=1.500000238
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=0.25
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=1
Stereo Boost Enabled=0
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=40
AZIMUTH change speed=0.5
Image phase amplifier=1.059999943
Image phase amplifier maximum angle=90.900001526
Image phase amplifier maximum separation strength=20
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=-0.350000024
Stereo Boost strength=1.25
Stereo Boost maximum amplification=1.25
Stereo Boost multiplier=0.75
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=16000
Highpass filter=20
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter enabled=1
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Device ID=
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Device ID=
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
Again, use the post below...
PostPosted: Tue Oct 27, 2009 12:15 am
Use this, if you want to include something (Thanks!):
[Common]
Pre amplifier=5
Post amplifier=1
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Enabled=1
Difference=0
Maximum volume=2
Maximum value=0
Above Top Limiter=1
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 2=7500
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5650
Maximum volume - Band 0=5650
Maximum volume - Band 1=5400
Maximum volume - Band 2=5750
Maximum volume - Band 3=4950
Maximum volume - Band 4=4050.000244141
Maximum volume - Band 6=3000
Maximum volume - Band 7=2330
Maximum volume - Band 8=2500
Attack speed - Band -1=0.000022769
Attack speed - Band 0=0.000022769
Attack speed - Band 1=0.000022769
Attack speed - Band 2=0.000022769
Attack speed - Band 3=0.000022769
Attack speed - Band 4=0.000022769
Attack speed - Band 5=0.000022769
Attack speed - Band 6=0.000022769
Attack speed - Band 7=0.000022769
Attack speed - Band 8=0.000022769
Decay speed - Band -1=0.000050483
Decay speed - Band 0=0.000050483
Decay speed - Band 1=0.000050483
Decay speed - Band 2=0.000050483
Decay speed - Band 3=0.000050483
Decay speed - Band 4=0.000050483
Decay speed - Band 5=0.000050483
Decay speed - Band 6=0.000050483
Decay speed - Band 7=0.000050483
Decay speed - Band 8=0.000050483
Above Top Limiter=1
Clipping enabled=1
Equalizer enabled=1
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=30.000001907
AZIMUTH change speed=0.600000024
Image phase amplifier=1.5
Image width amplifier=0.800000012
Extra phase shift=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=20
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Device ID=
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Tue Oct 27, 2009 3:30 am
It's included in this new version:
Command line: http://www.stereotool.com/download/ster ... d_BETA.exe
I'll try to release it tomorrow.
PostPosted: Tue Oct 27, 2009 4:28 am
Awesome.
Thanks!
PostPosted: Wed Oct 28, 2009 3:37 am
So... Wow... There are a lot of changes to this since version 3.x!
I already made another one using some of the new features. This is fantastic!
[Common]
Pre amplifier=7.5
Post amplifier=0.800000012
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Enabled=1
Difference=0
Maximum volume=1.75
Maximum value=0
Above Top Limiter=0
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=43500
Maximum volume - Band 2=18500
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=5800
Maximum volume - Band 4=3750
Attack speed - Band -1=0.000015691
Attack speed - Band 0=0.000015691
Attack speed - Band 1=0.000015691
Attack speed - Band 2=0.000015691
Attack speed - Band 3=0.000015691
Attack speed - Band 4=0.000015691
Attack speed - Band 5=0.000015691
Attack speed - Band 6=0.000015691
Attack speed - Band 7=0.000015691
Attack speed - Band 8=0.000015691
Decay speed - Band -1=0.00019322
Decay speed - Band 0=0.00019322
Decay speed - Band 1=0.00019322
Decay speed - Band 2=0.00019322
Decay speed - Band 3=0.00019322
Decay speed - Band 4=0.00019322
Decay speed - Band 5=0.00019322
Decay speed - Band 6=0.00019322
Decay speed - Band 7=0.00019322
Decay speed - Band 8=0.00019322
Above Top Limiter=1
Clipping enabled=1
Equalizer enabled=1
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=5
AZIMUTH change speed=0.400000006
Image phase amplifier maximum angle=125.099998474
Image phase amplifier maximum separation strength=50
Extra phase shift=0
Mono or stereo only=-0.300000012
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=20
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter relative volume=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Device ID=
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Wed Nov 18, 2009 1:00 am
Updated again (work in progress indefinitely!):
[Common]
Pre amplifier=5.659999847
Post amplifier=0.849999964
Extra loudness=1
Extra loudness - Punchy=0.224999905
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=8
Relative noise gate level - Band 6=3
Enabled=1
Difference=0
Maximum volume=2.25
Decay speed=0.004299093
Above Top Limiter=0.789999962
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 2=15000
Attack speed - Band 1=0.000001125
Attack speed - Band 2=0.000001125
Decay speed - Band 1=0.007
Decay speed - Band 2=0.007
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=7450
Maximum volume - Band 0=7450
Maximum volume - Band 1=6100
Maximum volume - Band 3=5250
Maximum volume - Band 4=4600
Maximum volume - Band 5=4600
Maximum volume - Band 7=2750
Maximum volume - Band 8=2750
Attack speed - Band -1=0.000043308
Attack speed - Band 0=0.000043308
Attack speed - Band 1=0.000043308
Attack speed - Band 2=0.000043308
Attack speed - Band 3=0.000043308
Attack speed - Band 4=0.000043308
Attack speed - Band 5=0.000043308
Attack speed - Band 6=0.000043308
Attack speed - Band 7=0.000043308
Attack speed - Band 8=0.000043308
Decay speed - Band -1=0.000043198
Decay speed - Band 0=0.000043198
Decay speed - Band 1=0.000043198
Decay speed - Band 2=0.000043198
Decay speed - Band 3=0.000043198
Decay speed - Band 4=0.000043198
Decay speed - Band 5=0.000043198
Decay speed - Band 6=0.000043198
Decay speed - Band 7=0.000043198
Decay speed - Band 8=0.000043198
Above Top Limiter=1
Clipping enabled=0
Relative clip position - Band 6=0.851851821
Relative clip position - Band 7=0.851851821
Final limiter value=0.508699954
Final limiter clipping=0.503759384
Equalizer enabled=0
Equalizer position - Band -1=1.352941036
Equalizer position - Band 0=1.150537491
Equalizer position - Band 1=1.150537491
Equalizer position - Band 7=1.352941036
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=35
AZIMUTH change speed=1.649999976
Image phase amplifier=2.5
Image phase amplifier maximum angle=140.399993896
Image phase amplifier maximum separation strength=75
Image width amplifier=0.649999976
Extra phase shift=0
Stereo Boost strength=0.5
Stereo Boost maximum amplification=3
Stereo Boost multiplier=0.449999988
Stereo Boost - Never reduce below original level=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=16500
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Device ID=
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Wed Nov 25, 2009 5:46 am
I think this is my last update to this for a while. I really like how well this is working! As with before, you can tune in to my stream here (with these settings):
http://superh.dyndns.org:8000/listen for low-bitrate HE-AAC (aacPlus)
http://superh.dyndns.org:8000/high for 128kbps MP3
Hvz: You've inspired me to continue development on my softDSP-based hardware solution. Be proud of your great work! :)
[Common]
Pre amplifier=5
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=3.75
Relative noise gate level - Band 5=2.508771658
Relative noise gate level - Band 6=4.405405521
Relative noise gate level - Band 7=3.651162148
Enabled=1
Difference=0
Maximum volume=2.5
Attack speed=0.000003096
Decay speed=0.002625912
Above Top Limiter=0.639999986
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=32500
Attack speed - Band 1=0.000008838
Attack speed - Band 2=0.000007557
Decay speed - Band 1=0.000089597
Decay speed - Band 2=0.000089597
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=6799.999511719
Maximum volume - Band 2=6799.999511719
Maximum volume - Band 3=4850
Maximum volume - Band 4=4200
Maximum volume - Band 5=2550
Maximum volume - Band 6=1699.99987793
Maximum volume - Band 7=1400
Maximum volume - Band 8=1849.99987793
Attack speed - Band -1=0.000011166
Attack speed - Band 0=0.000011166
Attack speed - Band 1=0.000011166
Attack speed - Band 2=0.000011166
Attack speed - Band 3=0.000011166
Attack speed - Band 4=0.000011166
Attack speed - Band 5=0.000011166
Attack speed - Band 6=0.000011166
Attack speed - Band 7=0.000011166
Attack speed - Band 8=0.000011166
Above Top Limiter=1
Clipping enabled=0
Final limiter value=0.457499981
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=1
AZIMUTH limit=35
Image phase amplifier=2.799999952
Image phase amplifier maximum angle=155.699996948
Image width amplifier=0.699999988
Extra phase shift=0
Stereo Boost strength=4
Stereo Boost maximum amplification=6.5
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=17500
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Device ID=
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Sat Dec 05, 2009 1:12 am
I think I have accomplished what I want with the high frequencies using the new stereo manipulation filter, "Stereo Boost". It seems like it is doing the logarithmic-decay high frequency reductions I am looking for. Still, it is a work in progress.
[Common]
Pre amplifier=4
Extra loudness=1
Extra loudness - Deep bass protection - Enabled=0
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=5.75
Relative noise gate level - Band 3=1.857142687
Relative noise gate level - Band 4=1.857142687
Relative noise gate level - Band 5=3.651162148
Relative noise gate level - Band 6=3.651162148
Relative noise gate level - Band 7=5.666665077
Enabled=1
Difference=0
Maximum volume=2
Attack speed=0.000001098
Decay speed=0.005926512
Above Top Limiter=0.159999996
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band 1=62500
Maximum volume - Band 2=22500
Attack speed - Band 1=0.000003152
Attack speed - Band 2=0.000003152
Decay speed - Band 1=0.000629348
Decay speed - Band 2=0.000629348
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=7000
Maximum volume - Band 0=6549.999511719
Maximum volume - Band 2=6359.999511719
Maximum volume - Band 3=5750
Maximum volume - Band 5=2500
Maximum volume - Band 6=1709.99987793
Maximum volume - Band 7=2350
Maximum volume - Band 8=1699.99987793
Decay speed - Band -1=0.000314613
Decay speed - Band 0=0.000314613
Decay speed - Band 1=0.000314613
Decay speed - Band 2=0.000314613
Decay speed - Band 3=0.000314613
Decay speed - Band 4=0.000314613
Decay speed - Band 5=0.000314613
Decay speed - Band 6=0.000314613
Decay speed - Band 7=0.000314613
Decay speed - Band 8=0.000314613
Above Top Limiter=1
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Stereo Image Enabled=0
Stereo Boost Enabled=1
Stereo Boost Excessive Reverb Protection Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
AZIMUTH change speed=0.899999976
Extra phase shift=0
Stereo Boost strength=6.5
Stereo Boost multiplier=0.25
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter relative volume=1.25
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
PostPosted: Thu Dec 10, 2009 2:23 am
I can't seem to get the sudden attenuation out of my settings with your DSP.
Here's another stab at it. This time, I'm using compress+limit.
[Common]
Pre amplifier=4
Extra loudness=1
Hard limit output=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=5.75
Enabled=1
Difference=0
Maximum volume=2.5
Attack speed=0.000000493
Decay speed=0.00593714
Above Top Limiter=0.280000001
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Attack speed - Band 1=0.000004831
Attack speed - Band 2=0.000004184
Decay speed - Band 1=0.000539601
Decay speed - Band 2=0.000539601
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=6609.999511719
Maximum volume - Band 0=6609.999511719
Maximum volume - Band 6=1900
Maximum volume - Band 7=2409.999755859
Attack speed - Band -1=0.000004539
Attack speed - Band 0=0.000004539
Attack speed - Band 1=0.000004539
Attack speed - Band 2=0.000004539
Attack speed - Band 3=0.000004539
Attack speed - Band 4=0.000004539
Attack speed - Band 5=0.000004539
Attack speed - Band 6=0.000004539
Attack speed - Band 7=0.000004539
Attack speed - Band 8=0.000004539
Above Top Limiter=1
Clipping enabled=0
Equalizer enabled=0
[Stereo]
Enabled=3
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=25
Extra phase shift=0
Stereo Boost multiplier=0.349999994
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Highpass filter=25
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
[FM Transmitter]
Enabled=0
Pre-emphasize=0
RDS PTY=0
RDS PI=65535
RDS TP=0
RDS TA=0
RDS Music=1
RDS Compressed=1
RDS Dynamic PTY=0
Enabled=0
Volume=1
Buffer size=1
Enabled=0
Device ID=
Volume=1
