Another great release Hans.
Quick comment on SSB - so far I have not noticed a significant difference to DSB, and had no listener comments, but I am yet to travel to a few spots where I Know multipath is at its worst. A not often mentioned benefit to leaving SSB running is the added high end bandwidth you can dial up while running RDS. That alone could make it worthwhile, and it gets a free ride with the excellent composite clipping! All good stuff.
While using it on the Omnia 9, I find that it makes the analog signal somewhat less damaged when having an IBOC station on an adjacent channel. I'm convinced it helps. Worth noting that careful listening will show a slight loudness loss using Standard and Extreme SSB modes (easily heard when airing White Noise and switched the SSB off/on), whereas Probably Optimal and Steep Optimal don't have any audible loudness loss. Whatever the Omnia 9 uses doesn't exhibit this loudness loss.
