Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 4 5 Next
 Post subject: Re: PC selection
PostPosted: Mon Dec 23, 2013 4:59 pm
So will 32bit 7 Pro be as solid/reliable as XP Pro?
PostPosted: Sat Jan 04, 2014 10:32 pm
I have just updated the initial post: With version 7.40 the required CPU speed is a lot less (when I wrote the post I could not run a complete preset with Stokkemask filtering on my laptop, now I can and I have some headroom left).
PostPosted: Wed May 13, 2015 6:23 pm
@ Hans
A memory card is not realy a wise thing to use i think
Memorycards cant cope with the continious writing in F.I. windows pagefile.sys
SD Cards have a limited read/write cycle
The cells wear out to fast causing problems
Pagefile.sys can be disabled but that can cause problems as wel.
I would use 2 single platter 5200RPM laptop disks in raid 1 or a single SSD like a 64 GB samsung 830 30% over provisioning
Test stream OGG
Test stream FLAC
PostPosted: Thu May 14, 2015 3:08 am
If you only run Stereo Tool you shouldn't need a pagefile - and if you have one it shouldn't (yes, I know, shouldn't) be written to if you only run Stereo Tool.
PostPosted: Tue Aug 11, 2015 1:28 am
I have re-run the calculations for Stereo Tool 7.71, and now it seems having 700 as Single Thread Rating in Passmark is sufficient. (That assumes that you're using 'Ignore highs frequencies', which slightly increases the latency). Without it the value should be around 800-900.
PostPosted: Tue Aug 11, 2015 10:58 pm
So, with te new version (7.71) it's possible to run an instance, just for web, with a core2duo e7600?
With latency at 4096 and quality at 100%.
Here passmark. http://www.cpubenchmark.net/cpu.php?cpu ... 40+3.06GHz
PostPosted: Tue Aug 11, 2015 11:41 pm
It should. Also that cpu easy go to 3.60GHz :)
PostPosted: Tue Aug 11, 2015 11:51 pm
You can probably run 2 full FM instances on that hardware!
PostPosted: Wed Aug 12, 2015 10:27 am
Those Core2Duos were good overclockers ;) You might consider OC that thing, as Bojcha said :D - today I will test my G1610T, 2300 passmark, 2.3 GHz 35W desktop CPU (you can get it -used- for about 10 bucks!). And faster G1610, 65W - even cheaper :D
PostPosted: Wed Aug 12, 2015 3:59 pm
Think i have an E8400 as well... hmmm my ST machine will suffer a downgrade soon :)
