Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon May 20, 2013 11:25 pm
Q9300 (not "E") will not work. with ST, FM, new composite and Full quality!
PostPosted: Mon May 20, 2013 11:33 pm
Intel Pentium E5200 @ 2.50GHz 1302 910 34.26
Intel Core2 Quad Q9300 @ 2.50GHz 3189 404 24.53
The second is better, tomorrow I call that shop, maybe they have a bit faster one.
Yes, Stokkemask is important. Station who pumped up their power will hear not much, but when your Stokkemask isn't right, then they can get a warning and fine after if it's still not right.
PostPosted: Mon May 20, 2013 11:35 pm
Thanks, I will not order that one.
PostPosted: Mon May 20, 2013 11:40 pm
well.. since you are searching whole configuration, you can always order something like that.. and get E8x00 CPU for example.. ;)
I replaced E5200 and E5700 with E8500 and clocked both to 3.60GHz (easy) and all is nice now. Ofc, XP pro 32bit.
Took some pics: :)
http://i.imgur.com/KbEYx0y.jpg
http://i.imgur.com/ddQUwdU.jpg
done: http://i.imgur.com/3sR6dlY.jpg
PostPosted: Tue May 21, 2013 9:49 am
@Bojcha - Where did you manage to find those 'older' processors? Did you get them through the used market?
I hope your OS install didn't give trouble after the change or did you do a fresh install?
PostPosted: Tue May 21, 2013 12:20 pm
I can get an system with E8300 2,83 gHz. It's Core2Duo. The last one, so maybe already sold
PostPosted: Tue May 21, 2013 1:15 pm
The second IS better but not that much, you need to divide the number by the number of cores (assuming that there are at least 2):
E5200: 1302 / 2 = 651 -> Running at 50% quality
Q9300: 3189 / 4 = 797
Q9450: 3792 / 4 = 948 -> Running at 80% quality, 70% with Stokkemask enabled.
So you need to have one that reaches at least about 1200 I think.
E8500: 2285 / 2 = 1143, but you overclocked it to 3.60 GHz (originally 3.16) so we need to multiply that by 3.60/3.16 -> 1302. Yea, that should work.
Note: Lowering the quality might not be that much of a problem, at the highest Latency setting (4096) you can easily lower it to about 50% without too much effect on the audio.
PostPosted: Tue May 21, 2013 1:16 pm
E8300: 1994 / 2 cores = 997. Close to my Q9450 which can do at most 80% quality, 70% with Stokkemask.
PostPosted: Tue May 21, 2013 3:11 pm
80% isn't 100% yet, so it's better to search for another system also for future development it's important too :)
PostPosted: Tue May 21, 2013 3:27 pm
http://i.imgur.com/xjXmhMX.png
http://i.imgur.com/sA8jfBh.png
@Bojcha - Where did you manage to find those 'older' processors? Did you get them through the used market? I hope your OS install didn't give trouble after the change or did you do a fresh install?
Found it or ricardo.ch. Used CPU. Price was 90CHF both.
No i did't need to reinstall windows. I however needed bios update since this cpu is newer stepping (E0).
