I don't know if this has been already mentioned, but I think the BS412-section reacts a bit weird in combination with MPX-Clipper and SSB on. Seems that it detects some peaks that aren't there (in DSB-mode), acts thereby more steeper than necessary, and that leads into a more noticeablely processed sound.
Would be nice if you will look into that, too. I'm very interested to use BS412 and SSB together for some field tests within the next days...
SSB should not do anything special, however I see that with composite clipping on there's an error: RDS and pilot are taken into account in the protection calculations (ie. the protector expects the audio level to be dropped by about 13%), but because composite clipping is used they should be ignored! Will fix that!
