That would be nice! ( i have a Q6600 cpu so maybe its enough )
Is the new clipper totally different?
Because,
When i set ST to normal out, and play some hardstyle music that is already processed, the sound is a bit cleaner/less distorted than when i set ST to FM out!
All settings are te same ( even advanced clipper drive is a bit lower with use of FM out)
And also played with FM composite over drive, but with normal out the sound is " nicer to listen to/less distorted/loud but more relaxed to listen to.
Like i said, with folk music i don't have this problem,
Only with already (heavely) processed hardstyle....
Can this be related to the use of the composite clipper, or is there something else that i must adjust?
