Post new topic  Reply to topic  [ 15 posts ]  Go to page Previous 1 2
PostPosted: Thu Nov 01, 2012 8:10 pm
I think you have some plugin that is not good or some non-standard settings in winamp..
I also know that also someone had same problem erlier. Me never had that problem. Only what i can do is to send you complete my folder and ini file so you can try to replace all and try. (?)
PostPosted: Thu Nov 01, 2012 8:34 pm
I just resetted my whole Winamp to Retail Settings and the Problem is still there!
I´m also using no other Plugins than Stereo Tool :/
PostPosted: Thu Nov 08, 2012 8:49 pm
*bump*
for the sake of people with the same issue - whenever it may occur!
PostPosted: Thu Nov 08, 2012 8:58 pm
Could you just send me the complete contents of your Winamp directory? Then I can try if I can reproduce it. Although I doubt I'll be able to reproduce it that way - but so far I'm just completely lost....
If that doesn't work the next solution would be that I add a lot of logging to ST to see if we can find out where it hangs - and if it's in Stereo Tool or outside of it. If you don't mind running tests?
PostPosted: Fri Nov 09, 2012 10:51 am
I´ll send you a PM with the Winamp-Folder!
I tested it on my X220 too and this was fresh Windows Set-up with Default Winamp Settings/SetUp (only changed output plugin to WaveOUT) -> same problem!
This is a complete other System than my Home PC and the error occurs there too.
How can it be that no one can reproduce this?!
No i don´t mind any tests, if i can help - i´ll do it (:
