Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 1 2 3 4 576 Next
PostPosted: Thu Aug 16, 2012 5:50 pm
Seems like only localhost:8000 en 127.0.0.1:8000 are working. But when connection with real ip:8000 it isn't working.
PostPosted: Thu Aug 16, 2012 5:59 pm
- Also ip:port from other device does not work
- Loading from file.sts is broken in some elements.
- Loading from stereo_tool.ini is ok
- ok, sts file from 6.32, loaded in 6.33, then saving as new file and again loading in 6.33 seems ok.
- soundcard output names broken, but works.
PostPosted: Thu Aug 16, 2012 6:19 pm
Using internal/external IP address does not quite bind to the port.
I see no issue with Sound card names being corrupt - probably because my OS language is in English.
EDIT: Indeed an issue with the sound card names in the application's configuration panel. I was under the impression the reported issue was in web interface.
visit website
PostPosted: Thu Aug 16, 2012 6:50 pm
http://beej.us/guide/bgnet/output/html/ ... etaddrinfo
This deens to be a much better networking tutorial than the one I used... Will try to fix remote xs and sound card names tonight.
PostPosted: Thu Aug 16, 2012 10:52 pm
Fixed sound card and remote access issues.
http://www.stereotool.com/download/ster ... 33-002.exe
GUI looks best in Google Chrome (so probably also in Chromium) and Opera, worst in IE. IE and FireFox don't show sliders for some reason...
PostPosted: Fri Aug 17, 2012 12:20 am
Look NO good in opera , some texts are over the sliders ...
looks very huge !!!but i think that it will be fixed day by day.Idea is awesome
P.S: Found a bug in MB when load the web interface there is a problem in the band 7 .. shows lower level and no move.
PostPosted: Fri Aug 17, 2012 12:26 am
Yea I started working on this 2 days ago, so don't expect too much yet.
Currently looking at sliders and how I can display a decent slider in all browsers... If possible something that looks better than the current sliders in Chrome/Opera/Safari.
PostPosted: Fri Aug 17, 2012 12:29 am
Look at band 7 Hans ... there is a problem
And some settings for FM interface enabling is not loaded correctly may be is changed something there :)
Now is band 3 ....
Don`t know if I enable/disable the MB through the web , or may be enable/disable the diff option .. something is goin wrong
PostPosted: Fri Aug 17, 2012 12:55 am
So what is going wrong? I haven't seen anything with the MB bands yet...
Some overall sound card settings were previously stored and loaded from STS files but not with this new version, I'll fix that.
PostPosted: Fri Aug 17, 2012 3:03 am
Hans first I want to congratulate you on the software. the new idea of ​​remote access is great! :D
Well, in my ipod touch, gets a bit complicated move the sliders, because many times when I try to do this, slide the web, but forgetting that detail works well. :)
In a recent netbook I realized that there are problems when the resolution is very small (at least in chrome), moves the position of the sliders, and overlap.
one last thing I think I should change the port since 8000 is commonly used for streaming shoutcast.
