PostPosted: Wed Sep 12, 2012 8:50 pm
Yes, and how is that involved with "ASIO"?
PostPosted: Thu Sep 13, 2012 5:06 pm
I thought the problem comes from ASIO(4ALL) because when i moved the buffer offset the problem disappered (temporary).
And ... yes, i think i simply forgot to say that i use VAC for the input.
PostPosted: Thu Jul 25, 2013 2:31 am
I know this is a very old post but in the meantime I found out what coused the truble, it was neither Stereo Tool nor VAC.
The problem was the buffer drift between VAC and my sound card because they run under different clocks (VAC with the CPU clock and the sound card with the PCIe clock). The solution was to add another VAC Cable and put Stereo Tool between them and use the Audio Repeater to stream the audio to the soundcard because the Audio Repeater has an automated clock correction.
PostPosted: Thu Jul 25, 2013 3:45 am
Ok, I've seen strange things in the Final Clipper output - but I'm not going to fix it now because I'm working on much bigger GUI changes.... :shock: (Will take some time, but I've finally started with a parameter interface code redesign, GUI redesign will be next!).
About the silence issue: Are you sure that none of the cores in your system peaks, and the CPU load doesn't increase, in this situation? I have noticed before that in case of absolute silence the CPU load can go up a lot.
Side note that in a much earlier release, I observed that the CPU load would increase if only 1 channel of ST had audio present. Attempts to duplicate that in recent versions didn't exhibit that behavior.
