Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Stereo Tool 6.30
PostPosted: Mon Apr 16, 2012 10:27 am
It was always a clipper, the name was wrong (lol, when I made it I didn't even really know what a clipper is)
PostPosted: Mon Apr 16, 2012 10:31 am
Anyway back to the matter at hand. I upgraded to Stereo tool 6.30 (standalone) earlier today with high anticipation. Now after listening for several hours, I have decided to revert back to 6.21. It has nothing to do with being humiliated here. :lol:
The reason is that I noticed my ears getting very fatigued from listening. Something very grating in the upper midrange/lower high frequencies. Sort of akin to listening to some of the early cd's when they had a noticeable harsh digital effect in the sound.
I would like to hear other's opinions and wonder if the problems are due to my preset (which hasn't changed) or other factors.
So can you give some details about your preset? Or maybe post it?
Does what you hear occur when there are louder bass sounds, or always? If it happens with louder bass sounds, it could very well be caused by the changed bass clipping behavior (and then you can fix it by changing some settings).
If you're using FM processing, you could try to turn the hole protection (new checkboxes in the lower right corner of the Loudness panel) off.
PostPosted: Mon Apr 16, 2012 3:52 pm
I'm more quiet now! :lol:
@Hans: To accompany the name change, you should update on the main screen, the name "Limiting & Loudness" with "Clipper & Loudness" and the text "Final Limiter" to "Final Clipper"
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Apr 16, 2012 5:04 pm
It's the BBC Omnia 1 preset from Phoenix, slightly modified with increased preamp gain (attached). I'm using for internet stream, not FM (or AM, gulp). It has a nice smooth mellifluous sound to my ears with ST 6.21. With 6.30, not so pleasing. Thanks for any feedback or comment.
File comment: packzap's preset
packzap_Preamp_x23_Sept2011.zip [4.08 KiB]
Downloaded 479 times
PostPosted: Mon Apr 16, 2012 6:41 pm
Haven't listened (have to go to NAB now), but I do see it uses pre-emphasis - so turning those 2 checkboxes off (Highs volume drop protection) might do something... Otherwise I don't see anything strange that would explain it (except maybe for the overall lows vs highs protection change).
PostPosted: Tue Apr 17, 2012 8:27 am
OK, I'll reinstall 6.30 when I get a chance and try toggling those two off and listen again with fresh ears. The reason I use a little pre-emphasis at around 11khz is to spice up the aac encoding for when the stream is played. Thanks again!
PostPosted: Tue Apr 17, 2012 2:28 pm
You mean 11us? 11us is not enough esepecialy for aac, but depend what peek level you keep for stream. should be around -2
PostPosted: Tue Apr 17, 2012 3:39 pm
Yes, sorry, I checked the panel ("lossy compression output optimization") and it's set at 10us (microseconds). And yes output level hitting the aac encoder adjusted to never get close to 0 (probably about -4).
PostPosted: Tue Apr 17, 2012 4:34 pm
-4 is ok. So you have room to pull down loudness and rise output by 2dB ;)
PostPosted: Wed Apr 18, 2012 12:28 am
Found a bug in the AGC. Sometimes when i load a preset the AGC doesn't work.
It then stays at the same level all the time.
