Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sun Mar 16, 2025 10:56 pm
Yes! the BB error and lost audio caused by ND is gone by 003.
PostPosted: Mon Mar 17, 2025 8:47 am
BETA004 is posted; the binaries have icons now (the same icon as before - no difference yet for different programs though so SST and PhoneBooster have the wrong one), and the console window no longer opens/closes.
PostPosted: Mon Mar 17, 2025 7:39 pm
Please also report changes in CPU usage between the old and new version. We need the following info:
- CPU
- Windows version
- Which exact version you're testing (stand alone 64 bit for example)
- Old vs new CPU usage
PostPosted: Fri Mar 28, 2025 7:20 am
Configuration: 6 cores/6 threads, Quality 150, lots of options on.
The old version ran RIST on uMPX, but it is not in the current version.
CPU -- Intel i9-13900K
Windows version -- Windows 11 (24H2/2025-03)
Which exact version you're testing -- Win64 Standalone v10.53-B004 [Compared to v10.51-B011]
Old vs new CPU usage -- 12.5% vs 13.4%
Old vs new CPU GUI -- 11.2% vs 10.1%
Old vs new Mem Use -- 613.1M vs 605.2M
EDIT: After running for around 5 days now, I came back to check it and found memory usage had decreased and is averaging 194.9M. I am not sure why the sudden drop but I do not believe I saw this occur in the v10.51 beta???
There have been no errors or issues so far, and the audio is fine. While RIST is missing, I understand that core services must be stable before adding it. :D
It's been surprisingly good when testing with both satellite and cellular feeds.
Ross
PostPosted: Thu Apr 17, 2025 2:32 pm
As a general Dante AES67 Output request.
Please if possible implement the Multicast Announcing via SAP as well.
Dante Controller only "sees" Multicast AES67 Streams if they are announced via SAP on the Network.
To use SDP Files you need to use Dante Domain Manager which is subscription only (and quite expensive for amateurs).
Subscribing Dante Devices to RTP Flows from Non-Dante Devices
RTP transmit flows need to be advertised on the network by the transmitting device. These advertisements provide the information required by receivers to subscribe to the flow. The flows can be advertised in a variety of ways.
Dante Controller supports RTP descriptors transmitted via SAP, and containing a range of specific values. Flows that are advertised this way will automatically appear in Dante Controller as a transmit flow.
For non-Dante devices that do not use SAP to transmit RTP descriptors, DDM must be configured to 'proxy' the descriptor via SAP so that Dante devices can subscribe to it.
source: https://dev.audinate.com/GA/ddm/usergui ... ight=AES67
As an alternative to make it work with Dante controller you could use a node.js script "hack" that announces the stream infos for it.
https://gist.github.com/philhartung/4d4 ... ef82793f19
PostPosted: Sun May 04, 2025 10:18 pm
There is finally a new beta again: 1053-006!
After multiple reports and about BETA004 performance, we have decided to switch to a different compiler. The CPU load is expected to be nearly identical to that of the last released version (10.51) now. And XP support is back. We have tested it on multiple systems and found basically identical CPU usage everywhere. Please let us know if you do find differences.
Once this is confirmed, we do have some changes that might improve the performance on some systems, but enabling that is the next step.
PostPosted: Thu May 15, 2025 5:10 am
Hi Hans
Running Stereo Tool v10.53 BETA009 on both Win64 Standalone and on uMPX.
uMPX is seeing the stream - well, it is seeing the GPS info from SFN from the sender - however, there is no audio stream?
I see the following error displaying every second...
! 2025/05/15 12:56:00 Bitstream error - decoding failed. Check the log for details (2x)
...for about 30 seconds, then...
! 2025/05/15 12:56:43 Packet buffer full... ignoring packet 2496615374
...that scrolls on a minute (packet number changes 2-3 times a second) and then stops.
I'm not sure if this was happening with prior versions in this beta due to the PI running uMPX being used temporarily in another project...
Ross
PostPosted: Fri May 16, 2025 3:26 am
Hi Hans
I keep forgetting to ask this. It is present in the current build (10.53 BETA009) but was also present in the earlier beta.
When processing, my CPU level is around 18.5-19% (Task Manager shows 9.3%). After about 30-40 seconds, when I stop the audio, the CPU level runs up to around 30-31% (Task Manager shows 12.5-14%) and hovers at this level until the audio returns.
Is there some form of watchdog/guard task causing this (i.e., is this an expected experience)?
Ross
PostPosted: Fri May 16, 2025 10:39 am
Instant crash on BETA1053-009 on MacOS (standalone).
Looks like the build system is making the app look for libraries in an absolute path on your system (e.g. '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libfdk-aac.2.dylib') instead of relative to the app package.
See below for full crash report. (apparently not allowed to attach txt files on this forum.)
Translated Report (Full Report Below)
Process: stereo_tool [22120]
Path: /Applications/ThimeoStereoTool.app/Contents/MacOS/stereo_tool
Identifier: com.thimeo.www
Version: 10.51 (???)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025-05-16 10:34:14.0389 +0200
OS Version: macOS 15.4.1 (24E263)
Report Version: 12
Anonymous UUID: 1CF7B052-1328-4842-B28D-FC747B4B5501
Sleep/Wake UUID: 5E020BE1-B4DB-446A-A932-EB64F691FB07
Time Awake Since Boot: 510000 seconds
Time Since Wake: 4897 seconds
System Integrity Protection: enabled
Dyld Error Message:
1
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: @rpath/libfdk-aac.2.dylib
Referenced from: <94253042-3349-3E7C-B69F-9771A4582CBA> /Applications/ThimeoStereoTool.app/Contents/MacOS/stereo_tool
Reason: tried: '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libfdk-aac.2.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libfdk-aac.2.dylib' (no such file), '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/libsndfile/libfdk-aac.2.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/libsndfile/libfdk-aac.2.dylib' (no such file), '/Applications/ThimeoStereoTool.app/Contents/Frameworks/libfdk-aac.2.dylib' (no such file), '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libfdk-aac.2.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/hansvanzutphen/remote/temp
(terminated at launch; ignore backtrace)
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000006 x1: 0x0000000000000001 x2: 0x000000016f17a4e0 x3: 0x000000000000006c
x4: 0x000000016f17a0e0 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x0000000000000020 x9: 0x7e09490041650014 x10: 0x0000000000001f80 x11: 0x0000000000020000
x12: 0x000000000001ac30 x13: 0x000000000001ac20 x14: 0x0000000000000001 x15: 0x0000000000000000
x16: 0x0000000000000209 x17: 0xcadd00016f179db8 x18: 0x0000000000000000 x19: 0x0000000000000000
x20: 0x000000016f17a0e0 x21: 0x000000000000006c x22: 0x000000016f17a4e0 x23: 0x0000000000000001
x24: 0x0000000000000006 x25: 0x0000000183a98000 x26: 0x000000001f070004 x27: 0x0000000000000000
x28: 0x000000016f17af60 fp: 0x000000016f17a0b0 lr: 0x0000000183b1fd18
sp: 0x000000016f17a070 pc: 0x0000000183b0ddd0 cpsr: 0x80000000
far: 0x0000000000000000 esr: 0x56000080 Address size fault
Binary Images:
0x100c84000 - 0x1029b7fff com.thimeo.www (10.51) <94253042-3349-3e7c-b69f-9771a4582cba> /Applications/ThimeoStereoTool.app/Contents/MacOS/stereo_tool
0x183a98000 - 0x183b32a83 dyld (*) <aca43a8d-6369-3a2c-af92-3d4c458523d6> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=651.4M resident=0K(0%) swapped_out_or_unallocated=651.4M(100%)
Writable regions: Total=16.6M written=96K(1%) resident=96K(1%) swapped_out=0K(0%) unallocated=16.5M(99%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
STACK GUARD 56.0M 1
Stack 8176K 1
VM_ALLOCATE 16K 1
__DATA 8763K 3
__DATA_CONST 990K 2
__DATA_DIRTY 7K 1
__LINKEDIT 621.6M 2
__TEXT 29.8M 2
__TPRO_CONST 128K 1
page table in kernel 96K 1
TOTAL 725.2M 15
Full Report
{"app_name":"stereo_tool","timestamp":"2025-05-16 10:34:14.00 +0200","app_version":"10.51","slice_uuid":"94253042-3349-3e7c-b69f-9771a4582cba","build_version":"","platform":1,"bundleID":"com.thimeo.www","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.4.1 (24E263)","roots_installed":0,"name":"stereo_tool","incident_id":"B0371410-C485-44CA-821A-D417ED672D8E"}
"uptime" : 510000,
"procRole" : "Background",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Mac16,11",
"coalitionID" : 56897,
"osVersion" : {
"train" : "macOS 15.4.1",
"build" : "24E263",
"releaseType" : "User"
"captureTime" : "2025-05-16 10:34:14.0389 +0200",
"codeSigningMonitor" : 2,
"incident" : "B0371410-C485-44CA-821A-D417ED672D8E",
"pid" : 22120,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2025-05-16 10:34:12.0195 +0200",
"procStartAbsTime" : 12340997649409,
"procExitAbsTime" : 12341046095032,
"procName" : "stereo_tool",
"procPath" : "\/Applications\/ThimeoStereoTool.app\/Contents\/MacOS\/stereo_tool",
"bundleInfo" : {"CFBundleShortVersionString":"10.51","CFBundleIdentifier":"com.thimeo.www"},
"storeInfo" : {"deviceIdentifierForVendor":"70E31AC1-0172-515F-AC5B-958F72E07696","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.thimeo.www",
"crashReporterKey" : "1CF7B052-1328-4842-B28D-FC747B4B5501",
"appleIntelligenceStatus" : {"reasons":["selectedSiriLanguageIneligible","selectedLanguageDoesNotMatchSelectedSiriLanguage","siriAssetIsNotReady","notOptedIn"],"state":"unavailable"},
"codeSigningID" : "com.thimeo.www",
"codeSigningTeamID" : "8Z2GPK5S3B",
"codeSigningFlags" : 570503953,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"codeSigningAuxiliaryInfo" : 0,
"instructionByteStream" : {"beforePC":"eAAAALwAAAAoAQAAcAAAAAABAABoAAAAGAEAADgBAAAwQYDSARAA1A==","atPC":"AwEAVH8jA9X9e7+p\/QMAkeEz\/pe\/AwCR\/XvBqP8PX9bAA1\/WEC2A0g=="},
"bootSessionUUID" : "482EED9F-FE4F-4A9F-9355-32EDE8FF902C",
"wakeTime" : 4897,
"fatalDyldError" : 1,
"sleepWakeUUID" : "5E020BE1-B4DB-446A-A932-EB64F691FB07",
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
"termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: @rpath\/libfdk-aac.2.dylib","Referenced from: <94253042-3349-3E7C-B69F-9771A4582CBA> \/Applications\/ThimeoStereoTool.app\/Contents\/MacOS\/stereo_tool","Reason: tried: '\/Users\/hansvanzutphen\/remote\/temp\/st_share_macm1\/BUILD\/build\/StreamingTool\/fdk-aac\/libfdk-aac.2.dylib' (no such file), '\/System\/Volumes\/Preboot\/Cryptexes\/OS\/Users\/hansvanzutphen\/remote\/temp\/st_share_macm1\/BUILD\/build\/StreamingTool\/fdk-aac\/libfdk-aac.2.dylib' (no such file), '\/Users\/hansvanzutphen\/remote\/temp\/st_share_macm1\/BUILD\/build\/StreamingTool\/libsndfile\/libfdk-aac.2.dylib' (no such file), '\/System\/Volumes\/Preboot\/Cryptexes\/OS\/Users\/hansvanzutphen\/remote\/temp\/st_share_macm1\/BUILD\/build\/StreamingTool\/libsndfile\/libfdk-aac.2.dylib' (no such file), '\/Applications\/ThimeoStereoTool.app\/Contents\/Frameworks\/libfdk-aac.2.dylib' (no such file), '\/Users\/hansvanzutphen\/remote\/temp\/st_share_macm1\/BUILD\/build\/StreamingTool\/fdk-aac\/libfdk-aac.2.dylib' (no such file), '\/System\/Volumes\/Preboot\/Cryptexes\/OS\/Users\/hansvanzutphen\/remote\/temp"]},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":8171524,"threadState":{"x":[{"value":6},{"value":1},{"value":6158787808},{"value":108},{"value":6158786784},{"value":0},{"value":0},{"value":0},{"value":32},{"value":9081870389015281684},{"value":8064},{"value":131072},{"value":109616},{"value":109600},{"value":1},{"value":0},{"value":521},{"value":14617839971673284024},{"value":0},{"value":0},{"value":6158786784},{"value":108},{"value":6158787808},{"value":1},{"value":6},{"value":6503890944},{"value":520552452},{"value":0},{"value":6158790496}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6504447256},"cpsr":{"value":2147483648},"fp":{"value":6158786736},"sp":{"value":6158786672},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6504373712,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":482768,"symbol":"__abort_with_payload","symbolLocation":8,"imageIndex":1},{"imageOffset":556312,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":104,"imageIndex":1},{"imageOffset":556364,"symbol":"abort_with_payload","symbolLocation":16,"imageIndex":1},{"imageOffset":48104,"symbol":"dyld4::halt(char const*, dyld4::StructuredError const*)","symbolLocation":312,"imageIndex":1},{"imageOffset":32900,"symbol":"dyld4::prepare(dyld4::APIs&, mach_o::Header const*)","symbolLocation":3820,"imageIndex":1},{"imageOffset":29060,"symbol":"dyld4::start(dyld4::KernelArgs*, void*, void*)::$_0::operator()() const","symbolLocation":236,"imageIndex":1},{"imageOffset":27392,"symbol":"start","symbolLocation":5924,"imageIndex":1}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4308090880,
"CFBundleShortVersionString" : "10.51",
"CFBundleIdentifier" : "com.thimeo.www",
"size" : 30621696,
"uuid" : "94253042-3349-3e7c-b69f-9771a4582cba",
"path" : "\/Applications\/ThimeoStereoTool.app\/Contents\/MacOS\/stereo_tool",
"name" : "stereo_tool"
"source" : "P",
"arch" : "arm64e",
"base" : 6503890944,
"size" : 633476,
"uuid" : "aca43a8d-6369-3a2c-af92-3d4c458523d6",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"sharedCache" : {
"base" : 6503055360,
"size" : 5020123136,
"uuid" : "bb86a9b4-8362-37b8-b028-212703af6f30"
"vmSummary" : "ReadOnly portion of Libraries: Total=651.4M resident=0K(0%) swapped_out_or_unallocated=651.4M(100%)\nWritable regions: Total=16.6M written=96K(1%) resident=96K(1%) swapped_out=0K(0%) unallocated=16.5M(99%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \nVM_ALLOCATE 16K 1 \n__DATA 8763K 3 \n__DATA_CONST 990K 2 \n__DATA_DIRTY 7K 1 \n__LINKEDIT 621.6M 2 \n__TEXT 29.8M 2 \n__TPRO_CONST 128K 1 \npage table in kernel 96K 1 \n=========== ======= ======= \nTOTAL 725.2M 15 \n",
"legacyInfo" : {
"threadTriggered" : {
"logWritingSignature" : "a3ac5b9b00930a860722c48ab071d36f559fdbff",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "654439cdafbf5b61207873a9",
"factorPackIds" : {
"deploymentId" : 240000004
"rolloutId" : "648cada15dbc71671bb3aa1b",
"factorPackIds" : {
"SIRI_EXPERIENCE_CAM" : "65a81173096f6a1f1ba46525"
"deploymentId" : 240000116
"experiments" : [
"treatmentId" : "4cfb9672-7b7b-42d8-a7dc-b675ffa2f5dc",
"experimentId" : "67f46877b1ea9f1f114b8d0b",
"deploymentId" : 400000001
PostPosted: Wed May 21, 2025 4:10 pm
Beta 10.53-012
Library not loaded: @rpath/libsndfile.1.dylib
Referenced from: <015FB1EB-C7CA-3641-B51B-90AF33732E68> /Applications/ThimeoStereoTool.app/Contents/MacOS/stereo_tool
Reason: tried: '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libsndfile.1.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libsndfile.1.dylib' (no such file), '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/libsndfile/libsndfile.1.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/libsndfile/libsndfile.1.dylib' (no such file), '/Applications/ThimeoStereoTool.app/Contents/Frameworks/libsndfile.1.dylib' (no such file), '/Users/hansvanzutphen/remote/temp/st_share_macm1/BUILD/build/StreamingTool/fdk-aac/libsndfile.1.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Users/hansvanzutphen/remote/temp
