Post new topic  Reply to topic  [ 134 posts ]  Go to page Previous 1 2 3 4 514 Next
PostPosted: Fri May 03, 2024 4:35 pm
Please, "Relative Stop Threshold" up to atleast +18 or +24 possible.
PostPosted: Fri May 03, 2024 5:59 pm
Having a problem with libVLC
Sorry if this isn't where the post belongs
whrn a stream is interrupted by an internet outage, the last second +/- loops until service is restorred and Stereo Tool is restarted.
I don't recall this being a problem in previous versions, but I don't know when this issue cropped up. It's doing this everywhere I use the VLC playout mode.
PostPosted: Fri May 03, 2024 6:21 pm
I'm not disagreeing; however, it might not be commonly known that 10.30+ includes the ability to manually enter out-of-range values when right-clicking. They should list this somewhere in the app for power users, along with the ability to use CTRL/SHIFT to modify the slider jumps, and CTRL SHIFT + to expand the contents of all cells.
PostPosted: Fri May 03, 2024 8:19 pm
Did you checked? Its not possible for that settings.
PostPosted: Wed May 08, 2024 6:01 pm
BETA004 is posted (we haven't gone through the comments here yet, so no changes in those things yet).
PostPosted: Thu May 09, 2024 8:34 pm
Hi Hans
the new version has problem to save new presets ...look at it...
PostPosted: Thu May 09, 2024 10:42 pm
Hi Hans
Yeah, importing presets doesn't ever show the in-app popup about what modules to load, nor does it appear in the list of presets.
PostPosted: Fri May 10, 2024 12:10 am
Hi Hans
Ow. It looks like part of the file name gets cut off for some reason.
Edit: Fixed. I'm going to run a new build now, so this was perfect timing :) .
PostPosted: Sat May 11, 2024 2:21 pm
:!: 10.31 BETA002 for PI4 This error occurs when updating: Bad data received, either more than 512 kB or not all data arrived!
PostPosted: Sun May 12, 2024 10:11 pm
The web interface is still malfunctioning on Safari in macOS unfortunately
