Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Tue Mar 26, 2024 7:27 pm
After several weeks of listening and tweaking, no new version but one last update.
PostPosted: Tue Apr 09, 2024 4:00 pm
Updated preset added for ST 10.30 with adjustments for the new EQ and Clipper.
More Stereo Boost and Delay.
Small adjustments of the Auto EQ and Compressors.
Adjusted Bass intermodulation distortion and Bass/Highs hole punch protection settings, should have less distortion especially in the highs.
Small adjustedments of the Sparkling highs and Open sound settings.
Speech detection, Phase delay and Stereo Reverb are set up but not activated.
PostPosted: Wed Apr 10, 2024 6:12 pm
Great vocals, 1.5 is definitely the best version yet. :)
PostPosted: Thu Apr 11, 2024 8:35 am
Thank you! just to know do you mean the one for ST 10.30?
Because I personally think the highs are cleaner and the bass a little more/deeper.
PostPosted: Thu Apr 11, 2024 8:47 am
Yes, I upgraded and tested version 1.5 on ST 10.30. Earlier preset versions on ST 10.2 always seemed to lack something, but not 1.5.
PostPosted: Thu Apr 11, 2024 8:57 am
Yes I thought so too, I will leave the preset like this, only updating it wth major changes in ST and maybe if I have some more time I will make a seperate one with the adaptive AGC/ Compressors.
PostPosted: Thu Apr 11, 2024 9:01 am
Yes, the adaptive compressors make huge difference and sound becomes much more "lively". With the latest version I also migrated to the adaptive AGC, but at the default settings I didn't hear any difference - the difference only came from the option to add additional density (Which, to me, sounds great and didn't cause any distortion).
PostPosted: Sun Jun 02, 2024 11:12 pm
Well done! A nice "hot" preset. Sounds great with 80's hits like Donna Allen - Serious. Too bright with modern music but that can be easily adjusted.
PostPosted: Thu Aug 01, 2024 1:24 am
A very late thank you, I haven't been on the forum for a couple of months and last few weeks been busy with a new preset.
