PostPosted: Sat Feb 04, 2023 3:18 am
On the good news front... Audacity can generate pink noise.
On the bad news front... I can't seem to locate my tuner which is in storage. I tried, unsuccessfully to record from a stereo systems headphone jack. So, this will need to wait until I can either locate the tuner or buy a second-hand one from somewhere.
I much appreciate your help though Bojcha.
PostPosted: Sun Feb 05, 2023 7:16 am
Sure you can check cables and connectors but something in transmitter is probably wrong.
If you can, play PinkNoise for about 20 seconds, use only Clipper!, attach some good tuner on other PC and record that, then upload here.
As requested @Bojcha.
Sorry, all I could get hold of is a GE Super Radio II. I used the the headphone jack to record. You might need to increase the volume. The radio has bass and treble controls, treble was left at 0, but bass was reduced (see pic attached). But even with it reduced, just looking at the EQ graph Mega uses while playing the track, the bass seems higher than the rest of the frequency range. Is this what we're looking for, or something else?
I hope this enough to work with.
I look forward to your response.
Cheers,
Baldrick
Audio: https://mega.nz/file/DfgjSIBS#NPYCK8c5Q ... Xh8phrplVQ
Pic: https://mega.nz/file/KWh0VQYY#wEku94--V ... gBZSAM-5pE
PostPosted: Sun Feb 05, 2023 8:17 am
Man what are we talking about here? :D
PostPosted: Sun Feb 05, 2023 8:26 am
You wanted me to send you a recording of pink noise to establish whether there was a problem with our TX?
"If you can, play PinkNoise for about 20 seconds, use only Clipper!, attach some good tuner on other PC and record that, then upload here." :)
