Post new topic  Reply to topic  [ 63 posts ]  Go to page Previous 1 2 3 4 57 Next
 Post subject: Re: BigFlex6 HD
PostPosted: Wed Oct 26, 2022 12:09 am
Hello. Here's how it sounds to me. v0.13 https://securestreams4.autopo.st:1826/grmljavina.m3u I didn't change anything in the settings. It is exclusively an Internet radio. I don't think it's bad, although maybe in some songs the guitars seem sharper than they should be.
Since it's not much intended for rock it sounds fine for what i am listening atm.
Veliki Pozdrav ;)
PostPosted: Wed Oct 26, 2022 8:49 am
Yes. Sounds great. That sharp sound of the guitars was only on one Neil Young live recording. I don't know exactly which album it is and which song it is. I can look in the log file, so I can send you that recording on PM so you can see what it is about.
PostPosted: Wed Oct 26, 2022 4:02 pm
I can check..
PostPosted: Wed Oct 26, 2022 11:17 pm
Hello. I found what song it is. I'm not sure I'll be able to access the music computer before the weekend. If it means anything, I can write the song info here. You may have it in your database.
PostPosted: Wed Oct 26, 2022 11:22 pm
Here is the data: artist - Neil Young & Crazy Horse, album Weld (Disc-1), track number 05, title Love To Burn.
PostPosted: Thu Oct 27, 2022 2:07 am
Checked, can't hear anything anoying stuff there, yes, there is MB adjusting spectrum and sometimes will reduce or amplify certain freqs. Also it might be a version of track is different. Those 2 i was listening:
https://www84.zippyshare.com/v/GEe8Mn3V/file.html
PostPosted: Fri Oct 28, 2022 8:10 pm
What is True Bass enabled for when Bands 1 and 2 are off in this preset?
PostPosted: Fri Oct 28, 2022 8:58 pm
Yea should be off fully. Saw it already, fixing few more things and ill post new version HD and FM.
PostPosted: Sun Oct 30, 2022 9:57 am
Thank you Bojcha. Quite impressive!
The only thing is, that we need to be in the region about 3dbr.
If I lower clipper, the result is not the same, otherwise great great preset.
PostPosted: Sun Oct 30, 2022 4:42 pm
I Didn't calibrated for that.
However, you can try to set bass to -2.5, and set clipper lower to about -1.00 and turn OFF sidechain in AGC, or just use BS412.
