Post new topic  Reply to topic  [ 257 posts ]  Go to page Previous 1 2 3 4 526 Next
PostPosted: Wed Jun 01, 2022 6:02 pm
Both GUI issues are fixed now. Will run a new build tonight.
PostPosted: Thu Jun 02, 2022 3:22 pm
Whenever I delete dsp_stereo_tool.ini and open ST it has a different window size (and position but that's expected).
PostPosted: Thu Jun 02, 2022 7:27 pm
oh, cool, the buffer displays, now have a percentage 8-)
PostPosted: Thu Jun 02, 2022 7:41 pm
How many times StereoBoost bar will be changed? Also this latest one expands in wrong direction - but depends on everyone's logic.
- Usually meters from up to down means attenuation.
PostPosted: Thu Jun 02, 2022 8:17 pm
Are you looking at the web interface or the native interface? It was upside down in the web interface, I just fixed that today. In the native interface it draws from the bottom, as it should.
PostPosted: Thu Jun 02, 2022 8:36 pm
Old/regular GUI.
beta14
PostPosted: Thu Jun 02, 2022 9:42 pm
Old/regular GUI.
beta14
Yes, I hadn't tested the old GUI anymore, and this broke. It also broke in the web interface so it turns out that we had already fixed it today, next beta should be ok again.
PostPosted: Fri Jun 03, 2022 3:20 am
beta14 - cpu processing usage numbers missing.
PostPosted: Fri Jun 03, 2022 10:27 am
Until now, percentage-displays automatically showed a percentage with 1 digit, we made that configurable - and forgot to add it to these meters. Solved, will be there in 016.
PostPosted: Fri Jun 03, 2022 10:36 am
BETA015 is available, all the displays should be correct again (except for the missing CPU load texts, that will be fixed in the next build).
