Post new topic  Reply to topic  [ 13 posts ]  Go to page Previous 1 2
PostPosted: Sat Feb 26, 2022 2:51 am
You cannot output it as Kernel Streaming? I've stopped using ASIO some time ago
Need Help? Call me, I can help you have a better sound with your actual audio processor, Analog? Unknown Brand? No Problem At All!
PostPosted: Fri Mar 25, 2022 8:33 pm
Only enable by placing the asio option the KS doesn't work, were you able to use the micrompx decoder with the alpha trace? :?
PostPosted: Fri Sep 23, 2022 8:43 pm
Try with this driver, it works for me: https://drive.google.com/file/d/19Es7vM ... sp=sharing
worked perfectly with this very good driver even the quality sound card is something else :lol: :D
