Post new topic  Reply to topic  [ 58 posts ]  Go to page Previous 1 2 3 4 5 6 Next
 Post subject: Re: Stereo Tool 9.80
PostPosted: Mon Aug 30, 2021 4:51 pm
Minor - if you click on window "SB" it sends you to the processing menu, not to single band.
PostPosted: Mon Aug 30, 2021 5:15 pm
Where is the link for the updated Declipper plugin, please?
PostPosted: Mon Aug 30, 2021 5:30 pm
Mac version is still 9.70?
Shouldn't be? It's the new build, I just verified it.
PostPosted: Mon Aug 30, 2021 5:32 pm
https://www.stereotool.com/download/dsp ... taller.exe
https://www.stereotool.com/download/vst ... lipper.dll
https://www.stereotool.com/download/vst ... per_64.dll
Let me know if you run into any issues, if not I'll upload them to the Declipper site as well.
PostPosted: Mon Aug 30, 2021 5:34 pm
4: Ah, of course. That makes sense. Thanks!
That fix will work, they're going to do that soon (probably within a few days). (This is about removing the Mr/Ms selection)
PostPosted: Mon Aug 30, 2021 5:38 pm
Added "Known issues" to the start post, this is a major release so chances are that there will be more things, so in a few days I expect to create a 9.81 update with fixes, if necessary.
PostPosted: Mon Aug 30, 2021 5:40 pm
Thanks Hans! I'll let you know!
EDIT: Found that the VST32 bit plugin, running inside BreakawayOne, is only taking about a quarter of the screen with the interface, the rest of the screen is filled with white space and the window cannot be re-sized. Otherwise, so far, so good.
PostPosted: Mon Aug 30, 2021 6:55 pm
Third, the License Info doesn't want to pop or whatever is supposed to happen when I click the button on the various places on the website.
License info and version number added to Stereo Tool, also added AGC 4 bands and Speech detection to the benefits of Advanced Dynamics. Other pages still need to be done.
PostPosted: Mon Aug 30, 2021 6:57 pm
I'm guessing you have a 4K-screen? The problem here is that whether the software should support 4K or not depends on the host application (Breakaway in this case), if there's a mismatch you can either get a too small or (much worse) too big display.
Was the previous version ok though? Because then it might be better to just turn 4K-support off completely for the VST. (I thought that the previous version had similar issues, but I might be wrong).
PostPosted: Mon Aug 30, 2021 6:59 pm
Not 4k, I'm not that fancy. It wasn't perfect before. Normally, I could resize the screen and it would snap to fill the box. But now, that's not working and I can't re-size the window.
