Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Sat Dec 12, 2020 10:29 pm
It's simple, you cannot replicate any other processor with ST, not even close.
I'm with Bojcha on this one. When I started with Stereo Tool, I was determined to try to mimic a processor, but be louder and cleaner.
If you clear your mind of all the old processors you used and go into Stereo Tool with a mindset of what sound you want to accomplish, you'll probably come up with your best work.
Early on, it was Bojcha's presets and work that inspired me to find a better way.
PostPosted: Sun Jan 24, 2021 10:55 am
Recently I've tweaked and added something to the old Impact MX preset.
I've added True Bass + MB2 + IB and Noise Gate, and lowered the Clipper drive.
Impact MX Edit by Krokodil V2.1.sts [123.73 KiB]
Downloaded 1389 times
PostPosted: Sun Jan 24, 2021 7:28 pm
Oh, yes, really like it. I lowered the threshold on AGC a bit (-13 dB) to make the compression less aggressive.
PostPosted: Thu May 13, 2021 2:28 pm
It is a really nice preset. But since I run a web radio, which should sound a bit more modern & pleasant, I like it when the Old Multiband runs rather so smoothly. So I adjusted the multiband compressor a bit. Music sounds Really Super, must say. I am a fan of it. Only I have a problem: I have a scratching on low music. Especially on chill out music. I made an example on a Windows sound, there you can hear it quite clearly.
I'll try again later to find an example with a song.
Best Regards
DEMO: https://workupload.com/file/fbg9uXKFk4r
PostPosted: Tue May 10, 2022 6:50 am
Something is wrong with Sound Return V4, the audio up and down all time, the fault is annoying.
https://fmfeeling.com
PostPosted: Tue May 10, 2022 3:07 pm
Yea AGC totally wrong
PostPosted: Tue May 10, 2022 10:07 pm
Orban 8600 MX preset sounds really bad with the latest StereoTool version (9.90). It seems that the latests changes in the Advanced Clippe is the cause. I've reset the values with the default Advanced Clipper settings and I think that is ok now
Orban 8600 Impact MX-AdvClipper-Mod.sts [125.37 KiB]
Downloaded 809 times
PostPosted: Wed May 11, 2022 12:14 am
I have run SoundReturn on my internet radio station for like 4 years now without any problems. Maybe the problems your having are with the newest version of Stereo Tool with changes to the advanced clipper.
No problem is preset, you just not hearing it. And problem is in AGC.
PostPosted: Fri Sep 22, 2023 7:11 pm
Hi all,
This present stopped sounding right a few versions of ST ago, and I wondered if anyone can work out why?
All the bass and treble has disappeared. It now almost sounds like an AM preset.
I'm running it in the new v10 beta and everything looks good on screen - for instance, the old multiband is showing up and looks fine visually.
I've tried changing settings in loads of places but can't seem to find the problem.
It feels like one of those things where someone will know one hidden setting that will make it sound right again, hopefully! 🙏.
If that's you, thanks in advance!
Ben
