Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4 5 Next
 Post subject: Re: Stereo Tool 9.40
PostPosted: Mon Apr 13, 2020 4:01 pm
Hans, is there a new beta version after the 9.40 release available for download?
No, not yet.
It seems that there is already a Beta Version for stereo tool 9.41 (https://www.stereotool.com/download/dsp ... 41-003.exe). May we know what are the recent changes?
PostPosted: Mon Apr 13, 2020 7:40 pm
The new beta's are work-in-progress, which is why I didn't make a post for them yet. There are bugs in the latest versions, among others they system tray icon is broken.
Anyway if you want to download it anyway, this is what changed so far:
  • STX: Adjust ranges of band mix, output level etc to max 6 dB. Say -3 to +3 dB. For other settings check ranges in existing presets, also for attack/release speeds etc.
  • STX: Lock CPU usage (should be easy), and maybe also latency?
  • "No heavy CPU processing": Change the behavior to a step lower for Peak mode in "sane" mode.
  • Declipper GUI bugs
  • Low latency half-HQ mode?
  • PhoneBooster improvement. Add maximum.
  • Reduce CPU load as tried at IBC, at least for STX
  • PhoneBooster add auto EQ/compressors?
  • PhoneBooster: Fix AGC display (right 2 bars need to disappear)
  • PhoneBooster: Add new settings
  • "Ignore high frequencies" does not work properly anymore for streaming presets in the last few releases
  • Pi version MicroMPX build (Model)
  • Pi version Stereo Tool crashes (9.40)
  • PhoneBooster: Added presets, and standard neutral preset
  • PhoneBooster: Made singleband compression visible in top bar
The CPU usage setting is probably the most interesting, if you set it to "Sane", heavy settings won't be so heavy anymore. This will for example lower the CPU usage of dynamic attack/release speeds in peak mode, or insane declipper or clipper settings.
PostPosted: Mon Apr 13, 2020 9:09 pm
Interesting improvements in PhoneBooster. Could you please share the download link for that.
-Janne
PostPosted: Mon Apr 13, 2020 11:50 pm
Thanks Hans 😀
PostPosted: Mon Apr 13, 2020 11:55 pm
-Janne
DSP version: https://www.stereotool.com/download/dsp ... 41-003.exe
Standalone Version (32 bit): https://www.stereotool.com/download/ste ... 41-003.exe
PostPosted: Tue Apr 14, 2020 7:27 am
-Janne
Thanks, but I meant a PhoneBooster and found it:
https://www.stereotool.com/download/Pho ... 41-003.exe
PostPosted: Wed Apr 15, 2020 1:09 am
9.41b04 on server. Example links:
https://www.stereotool.com/download/dsp ... 41-004.exe
https://www.stereotool.com/download/ste ... 41-004.exe
PostPosted: Wed Apr 15, 2020 1:30 am
Find a dsp/vst of the new Declipper yet?
PostPosted: Wed Apr 15, 2020 5:21 am
On 9.41 BETA 004, CPU usage seems to be a little bit higher (about 3 to 5 percent) than the release version of 9.40.
PostPosted: Wed Apr 15, 2020 5:23 am
Sometimes in Beta versions they enable extra logging and that uses more CPU. Not saying this is the case, but it's what I've understood in earlier instances.
