Post new topic  Reply to topic  [ 218 posts ]  Go to page Previous 1 2 3 4 522 Next
PostPosted: Thu Nov 21, 2019 8:23 pm
Any chance the scheduler bug will get some love? Currently, I have to manually massage my system after any restart to encourage the scheduler to engage. When the scheduler hasn't started, my stream fails to report title/artist information, putting my station out of compliance for licensing.
Great Hits and More!
http://RadioDAVE.US
PostPosted: Fri Nov 22, 2019 9:49 pm
When I try to use the Dynamic attack and release it comes up as an unregistered tool.
PostPosted: Sat Nov 23, 2019 5:09 pm
It's part of Advanced Dynamics.
PostPosted: Wed Nov 27, 2019 12:47 pm
Hello,
A few questions about Dynamic Attack and Release:
With the new Dynamic Attack/Release feature, how does that correlate with the manual attack/release settings already in place? Is it based off the user defined time constants in the traditional att/rel feature, or is there a set of special default att/rel settings that Dyn Att/Rel will base its behavior from?
If I want to use the Dyn Att/Rel instead of the traditional att/rel controls, does Dyn Att/Rel override that, or are they both running together at the same time?
If so, in a future beta, if a user wants to use one or the other, can it be made switchable between manual and automatic, e.g., if using manual att/rel settings, it turns off Dyn Att/Rel and vice versa?
Thank you.
PostPosted: Wed Nov 27, 2019 6:25 pm
Is it possible to change release 'shape' in Final Limiter ?
PostPosted: Wed Nov 27, 2019 7:01 pm
downloaded beta 008, what are the changes/fixes ?
PostPosted: Wed Nov 27, 2019 9:45 pm
Which final limiter do you mean? The one under "Advanced Clipper"? What do you want to be different there?
PostPosted: Wed Nov 27, 2019 9:51 pm
Hello,
Thank you.
Hi, the setting is relative to the traditional controls. So if you set the dynamic speeds to 2x/, that means that it can go at most twice as fast or twice as slow as the traditional setting. Setting this value to 1x/ disables it (1x as fast or as slow = no effect).
So, say attack is set to 1000 ms, and dynamic is set to 2x/, then the actual attack speed will move between 500 and 2000 ms. Same for release. The other two settings (reduce fast/slow movement) can be used to make it harder to get further away from the configured setting - set them high enough and you'll get the old behavior back.
PostPosted: Wed Nov 27, 2019 9:54 pm
First page post is updated!
PostPosted: Thu Nov 28, 2019 3:59 am
Yes, one in andvanced clipper.
Curently it looks like this (left) And should be more like this on the right.
Also, for some strange reason, sometimes with exact same input it's not always same release behaviour.
