I've changed the optimization settings.
Previously, EVERYTHING was optimized for speed.
Now, things that happen only occasionally (mainly initialization and moving sliders) are optimized for size. The rest is still optimized for speed.
The difference in speed should not be noticeable - and even if it is slightly slower, that should be compensated by the smaller file size which reduces the load time and the amount of memory needed (only by about 100 kB, but still).
The stand alone version now fits on a floppy again
(708 kB), DSP version is a bit too big (741 kB).
IMPORTANT: I still need to check if the processing performance is not affected by these changes. Theoretically it should be identical, but I'll test it tomorrow to be sure.
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... A502-8.exe
Stand alone version:
http://www.stereotool.com/download/ster ... A502-8.exe
VST version:
http://www.stereotool.com/download/vst_ ... A502-8.dll
VST version (No SSE2):
Command line version:
